413RB bored to 440
Old 09-15-2014, 09:23 PM
josehf34's Avatar
413RB bored to 440
Hi guys
I want to know if a 413 RB block can be bored to 440 and then made a 440 Big block build or isn't just as simple like it sounds. Will this affect the block structural integrity?
Old 09-16-2014, 08:47 AM
You need to do some research
413 was 3.75 bore
426 was 4.25 bore
440 was 4.32 bore
So from 3.75 to 4.32 is a whopping .57 inches!! That is more than 9/16"!!! Or if you're a "metric" guy that's 14.48 mm !!!!
Many modern engines cannot safely be bored "to" 1/8 (.125) overbore without sonic checking the block.
Old 09-16-2014, 12:10 PM
If you want a 440 get a 440 block or stroke your 413. the 413 is a good motor...
Old 09-16-2014, 05:31 PM
moe7404's Avatar
3.75 is the stroke for a 413. with out looking it up i think 413-426-440 are .060 apart. found this 413-4,18 bore-3.75 stroke---426-4.25 bore-3.75 stroke----440-4.32 bore-3.75 stroke. but i think the 413 is 4.185. but i dont have my of my pre 1967 manuals here. years ago there was group of max wedge racers out of FL that would take a 413 and bore it to 426 use it for a while, not sure they bored it to 440 to keep using again.
Old 09-16-2014, 06:15 PM
Don't know what I was thinking. 413 is 4.18, 440 is 4.32 it's still 140
The problem is finding pistons for either 413 or 426
Old 09-16-2014, 07:00 PM
moe7404's Avatar
yep you are right my brain IS going south. years ago my dad sold his 300 J that had a 500 in max wadge to a friend. who wanted it back to stock. dad found some cats that had a pair of 413 new in crate. so he ordered them. what came was one 413 and a 440. dad wanted to put the 440 in his 82 250 HD ram. but died the next week. and i sold the block.
Old 09-17-2014, 02:17 PM
DodgeAddict's Avatar
The 400 B block has a 4.32 bore That's why when you stick a turned down 440 crank in it becomes a 451 with a stock bore
Old 09-17-2014, 02:55 PM
moe7404's Avatar
if i remember right just cause the 383 and the 440 have the same bore doesnt mean they use the same piston. i think.
Old 09-17-2014, 03:28 PM
I'd stick with the 413. Steel crank with a good valve relieved piston at the right compression height could get you a great engine with a good aluminum head you could make 500 HP if you wanted.
Don't forget a stock bore 426 piston will fit that block with a bore. Still lots of selection.
Old 09-17-2014, 03:56 PM
moe7404's Avatar
but if iam right does it not make since that chrysler had a reason to make the 383 piston diff than the 426 piston? and you are right one could make a swap that way. and it might work. why am i flapping my gums when i have 67 manual on the floor next to me. i see what i can find.
Old 09-17-2014, 09:22 PM
josehf34's Avatar
413 was 3.75 bore
426 was 4.25 bore
440 was 4.32 bore
I'm not 100% sure but I think you're missing something, the 413 has a 4.18" bore not 3.75", 3.75" is the engine stroke. The bore difference between 440 and 413 is "just" 0.14"
Where I live is not simple like just bought a 440 block, a 440 here is a exotic engine to find so I thought that I could build a 440 RB from a 413 RB because if I'm right the unique difference between the 413RB and 440RB is the bore diameter. But seems to be not simple like I thought
So the 413 can be safely bore 0.07" over to make a 426 and use 426 pistons? is there a way that a 413/426 can be build to be a torque monster like the 440?
Old 09-18-2014, 04:33 AM
I would first source 20-30 thou 413 pistons and keep your options open.
As far "torque monster" sure, with the right head and modern camshaft, less top end HP and more low end torque is easily done.
Old 09-18-2014, 08:26 AM
moe7404's Avatar
i started reading in my 67 coronet manual. but did not to far i got side tracked. the the Hemi piston has a diff dome, and is forged, than the 383 piston. the 383 piston is NOT forged. and some of minor dementions are diff. and i think the Hemi wrist pin is is floating, and a diff dia. i wont say you cant use one. but i bet. what ever your need is some one has what you need , with out modding one. but making your own changes is what hot rodding is all about. i have very few things that are not moded.
Old 09-18-2014, 01:16 PM
I think you are referring to the 426 street wedge NOT the 426 Hemi
Old 09-21-2014, 04:44 AM
Gorts 5th's Avatar
Smile
Originally Posted by josehf34
Hi guys
Dont bore it my brother attempted thiat same thing
with objections from the machinest .
it lasted for about a week the the block cracked down the freez plugs
what a wast of a 67 max wedg 413 ... The heads we have to this day sitting atop a 440 but that block is trash .
u can wrk that 413 its a powerfull motor just check out the NHRA stats on that baybe..
Old 03-06-2020, 07:59 PM
George Dallas's Avatar
there were two 383 blocks, one with smaller pistons and long stroke, one w large 426.
Old 03-06-2020, 08:02 PM
John Van's Avatar
George, this thread is over five years old.
Old 03-07-2020, 09:37 AM
I think ole george is a bot/spammer.
Old 03-07-2020, 11:16 AM
Moe is a good Dude... I still chat with him even these days.. We talk at least 2 time a week..
Jimmy Mac
05-27-2017 10:58 PM
Chryslerguy17
01-18-2017 08:52 AM
Chryslerguy17
12-12-2016 09:46 PM
64Imperial
02-18-2016 08:10 AM
rondogg
11-09-2007 07:30 PM
Quick Reply: 413RB bored to 440
