Engine knock?
Old 01-24-2017, 07:49 AM
cmrris's Avatar
Engine knock?
I have a 360 Magnum swapped into my 1980 volare, and the motor had about 150,000 miles before I tore it down and put in new gaskets and the like. I didnt rebuild it because it was in excellent condition, still had cross hatching without any noticable wear on the cylinder walls. I started it last night and immediately it started makinging this sound-
https://youtu.be/fmBkdXCGZ-w
I know it already has a gasket leak at the header, but I didn't think it'd get this bad. I pulled the plug wires off one at a time and the noise didnt change and it seemed to go away with increasing rpm. I'm really crossing my fingers that it's nothing in the bottom end, but I'm wanting to get some others opinions on what it might be, any suggestions would be appreciated. I can get a better video today if I need too
Old 01-24-2017, 08:09 AM
Archer's Avatar
c -
It doesn't change when revving, so odds are it ain't in the engine. Sounds more like something is loose, rattling or possible making contact with something. Go over ALL the bolts and report back.
Old 01-24-2017, 09:16 AM
cmrris's Avatar
Originally Posted by Archer
c -
If I remember correctly, the Magnum flexplate was really close to the oil pan I used, so I'll definitely check everything including the converter bolts when I get out of class today.
Old 01-24-2017, 02:14 PM
Archer's Avatar
c -
If you have the protective cover for the torque converter on, remove it and see if the sound changes.
Old 01-24-2017, 04:28 PM
cmrris's Avatar
https://goo.gl/photos/wya3d8mY62RtY31P9
https://goo.gl/photos/mKRHn1gpbLGoXCbQ6
Well, I went ahead and check everything I could think of and it was all tight, so I changed the oil and opened up the filter and this is what I found...
Old 01-24-2017, 07:48 PM
Archer's Avatar
Charlie -
OK, that looks pretty bad, but doesn't account for the sounds in your video, since they didn't change with engine rpm.
Old 01-24-2017, 08:02 PM
Drag Pak's Avatar
Main bearings?
Old 02-08-2017, 06:58 AM
cmrris's Avatar
I finally got around to pulling the motor and tearing it down. I was beginning g to feel discouraged when all the rod bearings were looking okay, but then I took off the main caps...
http://goo.gl/photos/G7YQggt1xo8fUm7F9
https://goo.gl/photos/G7YQggt1xo8fUm7F9
How can the mains cause a sound like they did?
Old 02-08-2017, 10:25 AM
Make sure that you put a new oil pump on your parts list, I would because that one looks like it was run dry.
Old 02-08-2017, 10:46 AM
Drag Pak's Avatar
Loss of oil pressure = loss of oil wedge = metal to metal = knock, knock who's there?
Old 02-08-2017, 01:33 PM
No who's on first., whats on second and I don't know is on third!
Old 02-08-2017, 07:25 PM
felipec2106
12-04-2014 03:09 PM
75Duster360
11-21-2013 02:35 PM
RROriginals
10-18-2011 05:45 PM
ChargerBoy'71
12-19-2010 08:30 AM
ProEmaster
06-06-2007 11:31 AM
Quick Reply: Engine knock?
