2 ND Gear slip
Old 08-31-2013, 06:49 AM
pro-tech's Avatar
2 ND Gear slip
I have a 1972 Duster 360 street built somewhere between 350-400 Hp. It has a 904 torque flight transmisson. The other day I was driving and did 1st to 2nd shift and it spun the tires (It has a B&M shift improver upgrade in the valve body..I was on the go pedal pretty hard so it was planned) everything was fine with the shifts the rest of the day.Parked the car in the garage. A couple of days later I went for a cruise, and when I shifted to 2nd it slipped if I let off the gas and eased into it it was ok but as soon as I stepped down on the gas it would slip. I checked the fluid and now it reads over full, it was right on the mark before and now it is over full. Any thoughts....Bill
Old 08-31-2013, 07:13 AM
[QUOTE=pro-tech;108335... I have a good Idea, And know what it is. BUT this is a test of the knowledge here on this sight so answer carefully...Bill[/QUOTE]
Bye. Have a nice life. I don't have time for games.
pro-tech (08-31-2013)
Old 08-31-2013, 07:31 AM
pro-tech's Avatar
I didnt want you to answer anyway you my friend are just to arrogant and are in my opinion a know it all. That likes to try to show how smart you think you are... A nerd sota speak
Old 08-31-2013, 08:44 AM
slade's Avatar
BAM!!! so is this a legit thread or are you guys about to e thug. lol pro tech bring the duster up my way well put a 4 gear in it bud
Old 08-31-2013, 09:03 AM
That's a tough one. I would ask a 35yr Chrysler tech with master tech status.
Old 08-31-2013, 09:15 AM
Slade... No 9 Speeds allowed in a Duster........
Humm... Overfill.... Dont see how that can happen unless the radiator cooler is leaking.....
Sounds like the old (I have to lift off the throttle to make it shift to second) Valve body malfunction problem....
And for the better of all of us on the Forum... Please Guys agree to disagree
We are all here to give our opinion weather it's rite or wrong.... It's all about helping each other with our passion... Thanks Guys
Old 08-31-2013, 09:31 AM
slade's Avatar
have you seen the 9 speed auto? the zf ones? there nuts i would hate to work on them
Old 08-31-2013, 11:20 AM
Start with the basics Check the throttle pressure linkage, and Check the band adjustment
RacerHog (08-31-2013)
Old 08-31-2013, 06:50 PM
pro-tech's Avatar
Yup, your right As a 35 year master tech I know the answer. But it was just a test to see who else did. The problem is real and just wanted a second opinion to check myself. Before pulling the transmission to replace the teflon seal that failed filling the pan over full.. But some people on here just like to start sh-t and make people that dont really know or are in need of help.And then send them on a wild goose chase so they are so confused they look stupid.. And really how did that help them.. But after I disassemble it I will let you know for sure what it was..Have a good day all. As racerhog said we are all here to help one another if not than get the hell off the site...Bill
Old 08-31-2013, 06:54 PM
pro-tech's Avatar
Bob, the cooler is a dry cooler and doesnt go into the radiator. But thanks for the help.This all happened on one shift so a seal let loose inside I'll keep you posted...Bill
Old 08-31-2013, 07:09 PM
I don't understand how asking a question you know the answer to is helping anyone, maybe just your ego.
Why not use your experience to answer members questions and really help, like you say your trying to do?
440roadrunner (08-31-2013)
Old 08-31-2013, 08:00 PM
THANK you
Old 08-31-2013, 08:04 PM
I don't see how this "question" helps anyone. If YOU really want to "help" someone, post the whole blow by blow,
"My transmission did this"
I.....................did this,,,,,,,,,,,,,,,that...........checked this, thought it might be.......etc and discovered .................bla bla bla
You know when you posted this it would start a fight and that is exactly what you wanted.
Besides, none of the rest of us "are there" and don't know what you've checked or not
This isn't high school, and you are not my shop teacher.
Old 08-31-2013, 08:09 PM
slade's Avatar
bill were did u work for chrysler? or still do
Old 08-31-2013, 09:02 PM
pro-tech's Avatar
You dont know me. and I dont go on ego trips. Sorry if this upset you...Bill
Old 08-31-2013, 09:04 PM
pro-tech's Avatar
Your Right, Sorry, I'll keep you posted when I get it apart..Bill
Old 08-31-2013, 09:07 PM
pro-tech's Avatar
Slade, In numerous NY dealerships,..Bill
Old 09-01-2013, 08:08 AM
slade's Avatar
i gotta check out the car sometime man are you going to the adk nats in lake george?
Old 09-01-2013, 08:56 AM
pro-tech's Avatar
When is it? Where are you located? It also will depend on whether the car is fixed or not. If Im going to remove the transmission it is going to be completely rebuilt with kavlar clutches and a stall convertor, etc. which I should of done at the time of the build but got into to much of a rush to want to drive it. There was a car show on fathers day I wanted to attend and ended up in the hospital instead. But I will see whats what at the time and maybe I'll just go and check it out with or without the car...Bill
Old 09-01-2013, 09:10 AM
Awwww... The old "Morning Sickness" we called it.... When those failed it allowed the converter to drain back into the trans and they loved to leak out the dipstick and onto the floor !!!!!!
Keep us posted on what you find on the 1-2 shift problem..
Dont forget John @CRT....
http://coperacingtrans.com/
Old 09-01-2013, 09:29 PM
slade's Avatar
its this up coming weekend fri,sat,sun im in galway i was planning on going but my shift got changed so im working fri,sat nights so if i go it will be sunday but i wont have.my dakota its not quiye done yet
Old 09-02-2013, 06:48 AM
pro-tech's Avatar
What are the dates? And is it at Fort William Henry? There is no way Ill have Dusty done by then My lift is tied up right now and customer work is more important then toys...Bill
Old 09-02-2013, 10:15 PM
slade's Avatar
its the 6th 7th 8th the actual show is at the fort but the whole town is a show really
Old 09-03-2013, 06:33 AM
  #24
pro-tech's Avatar
Awsome, Ill see if I can get up there. Sounds like a good day trip...Bill
Old 09-03-2013, 08:08 AM
  #25
slade's Avatar
its a excellant trip haha
ZombiePopper
03-30-2020 05:58 AM
75Duster360
08-11-2013 07:58 PM
snaponbob
10-17-2012 04:34 PM
318scamp
05-02-2008 03:16 PM
318scamp
04-20-2007 06:35 PM
Quick Reply: 2 ND Gear slip
