904 auto. Transmission not shifting into gear
Old 09-10-2015, 10:01 AM
sm73charger's Avatar
Question 904 auto. Transmission not shifting into gear
Hey my 73 Chargers 904 Automatic Transmission hasbeen leaking fluid for years now because I havent driven it and the other day Iwent to back in out of the garage but it wouldnt go into any gear. I checkedthe fluid and it was almost completey out so I put almost 5 quarts in and ranit and tried it again and the shifter shifts into gears, but the car wont move.The parking brake is off, so I dont know why it wont go in any gear so I canmove it? Any thoughts?
PSits been sitting in my garage for 8 years just now getting to work on it.
Old 09-10-2015, 01:52 PM
moe7404's Avatar
if it has had no oil in it for a while. run it in neutral to load the hyd circuits with oil. in park it does not run oil throu the cooler. the to check the oil level run the gear shift throu all the gears then put it in neutral then check the oil level.
Old 09-29-2015, 05:08 AM
Maddog1800's Avatar
If the trans acts like it is working, make sure the brakes are not locked up!!!
Old 10-02-2015, 02:27 PM
Rooty's Avatar
Moe's absolutely right but let me expand on that thought. If it's been leaking, it can't get any lower than the top of the pan. I would recommend you drop the pan and watch the rooster cam (if you can see it) while someone shifts the gears (not running of course). I suspect the shift valve is cruded up and the filter as well. This will entail removing the shifter body with out dropping the tranny and cleaning it or have someone who knows how to do this if your not skilled enough. There's check ***** inside that really need to go back to where they're removed.
Old 06-22-2019, 02:33 AM
Michel Roux's Avatar
904
I have a 904 trans with 340 MOPAR SIX PACK. I have Park, Neutal, and only 2 speeds, first one short on and second long, is it normal or i miss one ??? Thanks. Mick
sm73charger
09-10-2015 10:03 AM
vanderlejm
07-12-2013 10:23 AM
maca
02-13-2013 05:16 AM
3rd1970RR
10-14-2012 04:28 PM
Austin The Rat-Rod Kid
10-09-2010 12:02 AM
Quick Reply: 904 auto. Transmission not shifting into gear
