What trans is this?
Old 04-06-2013, 08:11 PM
Ian Goolsby's Avatar
What trans is this?
I believe this trans may be the 0 A-833 FOUR-SPEED OVERDRIVE version but I need help from some of you pros identifying it for sure. Theres 2 numbers on it: C-13546 and Z5A0782. Looking forward to hearing which this is. Are parts fairly available for it if it needs rebuilding? Thanks so much guys.
Old 04-06-2013, 08:39 PM
rcknrolfender79's Avatar
Post a pic of the linkage on the side. I know some of these guys can tell you by seeing the linkage if it's an overdrive a833 or not. As far as rebuild kits go, you shouldn't have a problem finding a kit on ebay.
Old 04-07-2013, 06:02 AM
Gorts 5th's Avatar
Smile
there is a thread in here somewhere with the pic posted and description
Old 04-07-2013, 07:41 AM
mr340's Avatar
1. Is the case aluminum? yes=OD / no=depends on the build date
2. What size is the front bearing retainer (OD has 5.25" bearing retainer).
3. Is there a number stamped on the pad on the right side (eg pp833xxxx)xxxx is the
date code.
4. If the front shift rod points down it is an OD, if all three rods point up it is a
standard 4 speed.
5. Parts are easy to find: www.passonperformance.com
Old 04-07-2013, 07:53 AM
jacilynn_s's Avatar
Was wondering when someone would post about the front linkage pointing down.
Old 04-07-2013, 10:21 AM
It was on one of mine if I remember right. But the picture that was posted was very small and I couldn't see it real well. Figured we'd be better off if he posted a pic of his lol. How I knew someone would be able to tell by the linkage, by that shift lever pointing down.
lemontwist73
04-24-2008 04:47 PM
ppkaprince98
02-05-2008 12:07 AM
lotus79
01-21-2008 10:44 AM
rubadub
11-19-2007 11:02 PM
skimo0104
12-30-2006 09:50 PM
Quick Reply: What trans is this?
