very confused on my turning signals
Old 09-14-2016, 09:23 AM
73duster's Avatar
Question very confused on my turning signals
Hi hopefully someone can point me in the right direction. In my 73 duster the turning signals will only work if I have my headlights off and even then the back left will not work. also the on the front right running light it will only flash for the turning signal when the headlights are off but if the signal is not on then it will not turn on (I am thinking it is just a two way bulb and its just burnt out). Any help would be great and sorry if I didnt explain it very good.
Old 09-14-2016, 09:31 AM
Ran into something like on a non mopar a time or two, I'm thinking it was a headlight switch on the ford an a ground on the gm.
Old 09-14-2016, 01:23 PM
Archer's Avatar
73 -
Check ALL the fuses on that circuit and ALL the bulbs manually.
Then do as Iowan suggested, tracing the wires.
Old 03-28-2017, 07:14 PM
t65fury3's Avatar
just fixed my lights in the rear none were working it turns out someone separated the plug from the trunk to deck lid connection stupid stuff if all bulbs check good start with an ohm tester and start at the plug to ground sometimes it just isn't making contact to the body of the car.i had to change the mounting screws for the setup in one rear light for it to be grounded .anything is possible.good luck
Doubleclutch
11-03-2014 06:38 AM
moe7404
08-05-2013 05:52 AM
Groves 70 Cuda
05-20-2013 10:57 AM
firecrew13
07-29-2009 03:08 PM
69SatSport
05-02-2009 07:36 AM
Quick Reply: very confused on my turning signals
