1967 Satellite rear light switch
Old Mar 29, 2021 | 01:03 PM
sendust's Avatar
Hi guys my backup lights have not worked for years, I have an automatic on the console shifter, a while ago i lifted the console and found the switch in pieces. Recently i purchased a new switch and there lies my issue, as per the second photo the switch has wings attached to it, if i am correct this is not for my car, I feel that the wings should be removed and the switch should be installed into the metal slot as per the first photo. I will have to come up with a solution to attach firmly. Am i correct? if so any ideas on how to attach? thanks pete
Old Mar 29, 2021 | 07:26 PM
Thats switch is for a column shift car..... I think your switch in on the transmission? Has 2 or 3 wires hanging off it?
Old Mar 30, 2021 | 11:37 AM
sendust's Avatar
The connector for the switch power is in the console, the old switch i found still connected but in pieces in the same area pete
Old Mar 31, 2021 | 01:30 PM
Only one I see listed.... BWD S9148... ?
Old Mar 31, 2021 | 01:40 PM
sendust's Avatar
I think my issue is that someone in the past came up with there own system, i notice the wiring for the switch is in the console behind the shifter, it appears to have been rewired looking at the electrical tape around one of the wires, the female end does not match the switch i purchased, also as per my earlier photo there is a metal bracket attached to the drivers side of the shifter, the parts i found in the console had a pin in it like the switch i purchased but must have been a smaller switch, even with the wings removed the new switch is too wide. I will probably need to rewire the switch properly and attach at the transmission because i do not know how this worked, but it did work for the first few years of purchasing this car. pete
Old Mar 31, 2021 | 06:37 PM
sendust's Avatar
Feel a little foolish but figured out my switch issue, i now see there are two switches that look similar, one that attaches at the transmission and one that attaches at the shifter, the metal attached to the drivers side of the shifter is the old chassis of the switch that fell apart over time. I purchased the wrong switch, proper one ordered and issue will be resolved
Old Apr 2, 2021 | 07:12 AM
Hummm. Interesting.... So someone added a mother switch later in the cars life?
How did you source the switch?
You got my Curiosity up !!!!
Old Apr 2, 2021 | 06:43 PM
sendust's Avatar
No it is original, i checked the manual and it listed as a backup switch, when i bought the first replacement i called it a reverse light switch, i googled it and the switch i showed in my photo came up, this time i googled backup switch console automatic and it came up on a few suppliers, i purchased my new one from Classic that sells mostly Mopar. I guess it was just a few years it was attached to the shifter.
Old Apr 3, 2021 | 09:23 AM
Shoot us a photo when you get it and after installed, if you would....
I had a couple 67 cars with counsels but for some reason I don't remember this switch.. ( Then again, I am getting more forgetful ) lol
Cheers
Old Apr 3, 2021 | 05:17 PM
sendust's Avatar
sure will, i expect it in a few weeks
Old Apr 23, 2021 | 04:46 PM
sendust's Avatar
This is the new switch installed, works great pete
Old Apr 23, 2021 | 07:36 PM
Nice... Pete, Glad you got the rite switch and got it working correctly..... I had no idea that switch would have ever been mounted in that location..... One to file in the old memorie bank for 1967 Satellites....
98 SNAKE EATER
Apr 10, 2013 07:53 PM
Furyous68
Oct 12, 2011 08:10 AM
Aaron.Albrecht
Jul 30, 2011 10:24 AM
frees74
Dec 29, 2010 05:34 AM
Dave MoorePower
Aug 11, 2008 05:59 AM
