from a 318 to a 440
Old Nov 9, 2007 | 07:45 PM
You'll need big block motor mounts for your year of car, including the engine brackets and the rubber mounts0--separate pieces
You'll need the proper big block transmission--SB and big block patterns are different.
I don't know about the rear trans mount
You might have to switch the lower radiator outlet to the opposite side, and the radiator might not be big enough.
Power steering brackets, etc, misc
Depending on what transmission you find (tailshaft length) you might have to make a new driveshaft, or shorten yours.
It would be FAR easier to put a 340/360 in that car, pretty much a bolt in.
Depending on what the 440 is out of (a truck?) the manifolds might be troublesome, unless you plan headers, ditto with the pan. I'm sure your car still uses a front sump pan.
mosquito13
May 17, 2012 03:01 AM
hcharles
Feb 5, 2011 03:52 PM
TallChris
Dec 1, 2010 03:29 PM
LittleSpark
Jan 15, 2009 09:06 PM
ProEmaster
Jun 6, 2007 11:31 AM
