318 swap
Old May 5, 2015 | 08:59 PM
Juan_L's Avatar
318 swap
I have a 1974 Dodge Charger and i was wondering what year 318 will fit in my car without much change? Im thinking about getting a 1967 318 to swap but i wanna know if itll swap straight through.
Old May 6, 2015 | 08:27 AM
DDodger's Avatar
Somewhere around 67 --68 is when the crank register changed. Older (273) used a small snout register for the torqueflite, if that's what you have. If you have a stick, regardless of year, the pilot bushing hole may be undersized -- not finished machined--and some were not deep enough
So I'm going to say 68 / later. You need a front sump pan, IE not a rear sump out of a pickup, van, motor home.
What was originally in the car?
Old May 6, 2015 | 07:15 PM
Juan_L's Avatar
It has a original 318 but the block has a hairline crack in it. Has original 904 auto transmission.
Old May 6, 2015 | 08:09 PM
Go ahead and use it. Just use your accessories as needed. Install all new external gaskets & freeze plugs before installing it....
notta _mech
Sep 13, 2011 09:42 AM
mopar528dakota
Dec 20, 2010 02:30 AM
chlngr1970
Sep 30, 2010 08:54 AM
fpereira23
Sep 14, 2008 09:42 AM
66coronetgirlie
Dec 18, 2007 07:06 PM
