65 Coronet 440 problems
Old Dec 8, 2011 | 12:41 PM
78doubleR's Avatar
Hey all-
one of my customer cars is acting really weird. some background of the car: 1965 Dodge Coronet 440 weiand dual-quad intake with dual carter 600cfm carbs. The cam is hot enough that it doesn't need a vacuum advance and it was dyno tuned by mr. norm (i think). The car was restored in Florida, sent to Denver, Colorado and now it resides in my shop for my customer in Beaverton, Oregon.
Symptoms: Running like its a diesel, hard to start and keep running and won't rev past 1k rpm with foot to the floor. It ran great a week ago and i go to move it out of the shop and it started up great and i let it warm up then go to back it out and as i get out of the shop and head down the driveway it doesnt wanna go. doesn't make any sense to me.
Whats been replaced: Fuel filter, rods/jets in the carbs have been tuned for sea level instead of high alt., YES there is gas in the tank, just put $50 of premium in it.
What do ya'll think?? I need suggestions asap! Thanks for looking
Old Dec 8, 2011 | 12:48 PM
Ignition system?
Old Dec 8, 2011 | 01:36 PM
See if gas is pouring into the intake. Piece of crap could be stuck in the needle valve keeping the float from closing. Too much gas will make it run like crap. 600 cfm carb did it to my Aspen.
Old Dec 8, 2011 | 06:19 PM
Silverick's Avatar
Sounds like a bad fuel pump to me....
Old Dec 8, 2011 | 08:40 PM
78doubleR's Avatar
See if gas is pouring into the intake. Piece of crap could be stuck in the needle valve keeping the float from closing. Too much gas wil make it run like crap. 600 cfm carb did it to my Aspen.
Not dumping in that I know of.
That's what I was thinking. But i dont think a fuel pump would just up and go out.... Idk though, it could happen i guess.
Old Dec 9, 2011 | 08:11 PM
scotts74birds's Avatar
As a shop, do you have the ability to check the exhaust for A/F ratio? Until that, I will go with what my mentor taught me, "80% of carb problems are in the distributor".
Old Dec 9, 2011 | 08:25 PM
78doubleR's Avatar
No I don't but we wanted to put it on a dyno sometime soon to figure out the afr and see what she puts out at the wheels.
Please elaborate for me: "80% of carb problems are in the distributor"
Old Dec 9, 2011 | 11:26 PM
I still think you broke a piece of dirt loose and it's causing you carb problems....You found anything yet RR.
Old Dec 10, 2011 | 08:37 AM
John Van's Avatar
Did you check the ignition timing? Almost sounds like the timing chain.
john
Old Dec 10, 2011 | 09:41 AM
If I have a fuel delivery problem I take a spray bottle of gas (mist) and while it is running with the trottles open slightly spray directly into carb(s). If it speeds up it is lacking fuel, if it stumbles and quits it already has too much. A helper and a fire extinguisher is a good safety practice. Good Luck, keep us posted.
Old Dec 10, 2011 | 05:11 PM
Archer's Avatar
78 -
Just curious - is it running SUPER rich? Like you could choke on the fumes rich?
Old Dec 10, 2011 | 10:44 PM
78doubleR's Avatar
Originally Posted by Archer
78 -
it was running rich, like normal rich, not super rich.
xvodysseusvx
Jun 25, 2018 04:38 PM
SteveRT
Oct 15, 2014 04:24 PM
TheSkycrane
Jun 14, 2014 07:48 AM
dougal
Nov 18, 2012 06:46 AM
the bigedbosky
Jan 17, 2009 05:27 AM
