83 B150 Ram Slant 6 Misfiring after doing EVERYTHING! Frustrated! Pls Help!!!
Old May 15, 2009 | 12:12 AM
scotts74birds's Avatar
Mentioned this to a buddy the other day, if you have access to an IR laser thermometer, you can find out if you have a problem in a certain cyl. by reading the exhaust temp at that cylinders exhaust port. Headers are easier, but it should work on a cast iron manifold also. You will have a cylinder that is much cooler or hotter than the rest of them. they are about 50 bucks from Harbor freight these days and are a part of the new millenium of tuning tools. Embrace technology or perish.
Old May 15, 2009 | 01:18 AM
johnthegoalie's Avatar
thinkin with me dipstick
have you taken the distributor out yet? i have heard that the gear going bad is pretty common...
Old May 15, 2009 | 01:49 AM
If it is a misfire, then you need to find out if it is the same cylinder every time or a different one. You timing could be off some causing the same problem. Like John said, the gears are known be go bad on these because they are plastic. Has the carb been rebuilt/replaced at all? Have you used a spark tester (it goes between the plug and wire. It is a little light). It will show you the amount (so to speak) of spark going through. The brighter the light, the better the spark.
Old May 15, 2009 | 08:11 AM
you can still get distributors at checker and as of a few years ago the dealer still had them. i was lucky enough to score a brand new mopar performance unit when i converted from points ot electronic.
Old May 15, 2009 | 04:30 PM
have you removed the valve cover yet? i could be waaay out in left field, but check if you have a bent pushrod.
you have me thinking, mine was running crappy, then really crappy, took off the valve cover to find a broken pushrod...
Old May 15, 2009 | 10:49 PM
Nice graph! Dont know if I could have done that in 3 days with a whole box of crayons! You dont drag your feet on things, do you! Seems like there was some info there. You would wxpect that 1 and 6 be a little cooler being on the ends, but over 25% cooler than the average says thats your boy. Asooty plug on 6 also says its not running hot enough to clean itself. Your on track, good luck.
Old May 16, 2009 | 02:42 AM
Polaradude's Avatar
Just my 2 cents, I think we are over complicating things here. Like John said pull a valve cover, check valve lash/ geometry. Look for a broken spring. etc etc. After all it's just a big air pump, air in / air out.
Nice graph though.
Old May 16, 2009 | 08:12 AM
Originally Posted by rabino34
You didn't hear the valve doing something funky (clanking, tapping, etc.) before the valve cover was removed?
pretty good cam, solid lifters and a loose lash, the valvetrain is always noisy - what i was getting at is maybe one might be bent...
Old May 16, 2009 | 01:55 PM
Rebuilding that carb would be EASY. Geez Rab, you seem to get more done in a day than I can do in a month of Sundays! Not on meth are you? LOL
Old May 16, 2009 | 02:06 PM
  #24
Polaradude's Avatar
Are the carb pieces wrapped up in paper ?? lol
Old May 16, 2009 | 03:25 PM
  #27
if he was tweekin on meth, the dodge would be in a million pieces and all the wires stripped...
Old May 16, 2009 | 03:29 PM
  #28
LOL Right on!
Old May 16, 2009 | 04:35 PM
  #30
Polaradude's Avatar
OOh that's funny.
