Aluminum Water Pumps
Looks like my overheating problem maybe related to the pump. Anyone ever have any issues switching to an aluminum water pump? Any considerations when going to an aluminum pump?
Thanks
Thanks
An alum water pump will just displace some heat for you. If your looking for more flow, then you want a high flow water pump. If your having an issue with overheating, take a look at some of these simptoms then.
Stuck thermostat
bad clutch fan
clogged radiator
air pocket
weeping water pump
no fan shroud on the radiator
I'm sure that there are more but these are the main causes of overheating. Have you upgraded anything on the motor recently performance wise?
Stuck thermostat
bad clutch fan
clogged radiator
air pocket
weeping water pump
Thats a biggie! A shroud can drop the temp on the gauge by 25 degrees!
Also a out of tune engine will also run hot. I had a issue last spring where the car was over heating, to the point there was excessive pressure in the rad, changing the water pump had no effect, turned out the timing was off a bit, but it caused the temp to rise tot he point it was boiling the coolant!
I was told by an older mechanic,if my car is over heating ,is to remove the thermostat and use a flat peace of aluminum and drill a 5/8 hole in the centre of it ,and use it as the termostat and the engine will not go over 190.He is the mechanic for a friend of mine ,and they race in cascar.They say this works ??
Find a cure for the cause, not the symptoms. Why is the car overheating, what else is the car doing? Have you pulled the plugs to see what they look like? Are you burning oil, blowing smoke from the exhaust etc! what's the timing set at? When was the last time you had a rad and coolant flush? do you have the right thermostat and is it in the right way round?
