Aluminum Water Pumps
Old Jul 20, 2009 | 01:57 PM
mikeynags's Avatar
Junior Member
Looks like my overheating problem maybe related to the pump. Anyone ever have any issues switching to an aluminum water pump? Any considerations when going to an aluminum pump?
Thanks
Old Jul 22, 2009 | 07:26 PM
71satellite's Avatar
Junior Member
i just put a bosch alum pump on my car. it overheats unless the thermostat is out. could never figure it out but maybe thats my problem.
Old Jul 23, 2009 | 02:00 AM
An alum water pump will just displace some heat for you. If your looking for more flow, then you want a high flow water pump. If your having an issue with overheating, take a look at some of these simptoms then.
Stuck thermostat
bad clutch fan
clogged radiator
air pocket
weeping water pump
no fan shroud on the radiator
I'm sure that there are more but these are the main causes of overheating. Have you upgraded anything on the motor recently performance wise?
Old Jul 23, 2009 | 04:09 PM
aluminum pumps will get ride of heat faster
Old Jul 23, 2009 | 05:03 PM
64fury's Avatar
Thats a biggie! A shroud can drop the temp on the gauge by 25 degrees!
Also a out of tune engine will also run hot. I had a issue last spring where the car was over heating, to the point there was excessive pressure in the rad, changing the water pump had no effect, turned out the timing was off a bit, but it caused the temp to rise tot he point it was boiling the coolant!
Old Jul 27, 2009 | 05:14 PM
mikeynags's Avatar
Junior Member
Could it be possible I have the wrong radiator in the car? Both hose outlets/inlets are on the drivers side....
Old Jul 27, 2009 | 06:10 PM
pjmopar's Avatar
I was told by an older mechanic,if my car is over heating ,is to remove the thermostat and use a flat peace of aluminum and drill a 5/8 hole in the centre of it ,and use it as the termostat and the engine will not go over 190.He is the mechanic for a friend of mine ,and they race in cascar.They say this works ??
Old Jul 27, 2009 | 09:03 PM
64fury's Avatar
Find a cure for the cause, not the symptoms. Why is the car overheating, what else is the car doing? Have you pulled the plugs to see what they look like? Are you burning oil, blowing smoke from the exhaust etc! what's the timing set at? When was the last time you had a rad and coolant flush? do you have the right thermostat and is it in the right way round?
Old Jul 28, 2009 | 06:03 AM
mikeynags's Avatar
Junior Member
It's not burning any oil, no smole etc. I'll double check the timing, haven't check it yet and I also need to pull the plugs. I just did a coolant flush/replace last week and replaced the t-stat and it is in properly.
Old Jul 29, 2009 | 03:01 PM
have you tested the pressure in the radiator?
Old Aug 2, 2009 | 06:02 AM
mikeynags's Avatar
Junior Member
Pressue seems to be ok - about 16 lbs. Replaced the cap as well.
Old Aug 3, 2009 | 03:56 AM
What is the car?
You could have an air pocket stuck somewhere since you flushed the system. Just a thought.
Old Aug 9, 2009 | 03:52 PM
mikeynags's Avatar
Junior Member
What is the car?
The car is a 70 Roadrunner
69Ronrunner
Feb 21, 2013 07:19 PM
plymouthrr1985
Apr 1, 2009 03:29 AM
Commando
Nov 24, 2008 07:27 PM
mbridge1
Jan 28, 2008 09:30 PM
shadowwolf30
Cuda Specific Discussion
Oct 31, 2007 12:55 PM
