A-body to B-body questions
Old Jan 21, 2011 | 08:20 PM
66coronet440's Avatar
Question A-body to B-body questions
im looking into getting a suregrip carrier unit out of an a-body 8 3/4 rear end into a 8 3/4 b-body and wondered if it worked. Also is the a-body "big bolt" pattern the same as the b-body? because i wanted to take the spindles from an a-body and put in my b-body, so i can have front disk brakes. thanks
__________________________
1966 Coronet 440 318 poly
Old Jan 21, 2011 | 09:00 PM
MercuryDon's Avatar
If both cars are 8 3/4 diffs. The pumpkins should interchange. The large A body bolt pattern is the same as B body. Just measure accoss the studs if your unsure.
Old Jan 23, 2011 | 08:05 AM
ok thanks, so the actually carrier should interchange, but are the axle ratios the same?
Old Jan 23, 2011 | 10:45 AM
62Furious's Avatar
look at the ring gear it will have a stamp with the gear ratio, you will need the spindle to convert drum to disc and I do not know if the A-body is the same between ball joint to ball joint as the B-body
Cazbah362
Aug 21, 2011 06:25 PM
MoparMan76
Jan 14, 2011 01:31 PM
BigPaddle
Jan 21, 2010 07:04 PM
ngc414
Jul 7, 2009 10:14 PM
chlngr1970
Aug 1, 2008 09:26 PM
