Floor shifter conversion help
Old Sep 7, 2009 | 02:11 PM
Apollo's Avatar
Find another 71-74 Charger with the slaptick 904 tranny setup and just convert everything over.
Old Sep 9, 2009 | 12:09 PM
Apollo's Avatar
I think those are just cable operated. It just might be a matter of mounting it in your desired spot and running the shifter cable, neutral safety switch and back-up light switch.
Old Sep 10, 2009 | 04:17 PM
Apollo's Avatar
You got me thinking about the install on aftermarket shifters and i found this. Ive only installed ratcheting shifters in sandrails so I had to check.
http://www.dodgecharger.com/forum/in...=42416.0%3Ball
You can actually avoid the pain of running the cables and utilize the stock linkage with the ratcheting units. Might help . .
As for my Charger, shes sadly been on the backburner. Ive done minor things here and there, but nothing that required more than 30 minutes or so of my time because i just havent had any recently. She runs, drives and smokes one tire very nicely though. Just needs a lot of fine tuning and odds'n ends need to be buttoned up. Ive been dying to get the hood back on so i can see that scoop sticking out, menacingly urging me to drive the car like i stole it. Soon i hope.
Old Sep 10, 2009 | 06:30 PM
scotts74birds's Avatar
I agree with the thought of using and aftermarket shifter in a stock application. I had a built 78 Z-28 that I installed a B&M Mega-Shifter into. I loved it!! Great shifter. But they made it only to fit that car and console. I'd like to do the same to my 74RR, but it might take more work than I want to do.
Old Sep 15, 2009 | 04:33 PM
koondawg_74 roadrunner's Avatar
I have a 1972 mopar service manual that our friend bought from a dealer and it has diagrams of both floor and column shifters. I had to make a shifter linkage for my rr. If you might need it, I can copy it on here.
Harlyman
May 22, 2012 04:27 AM
volarerr340
Mar 15, 2011 07:56 AM
valpip
Nov 3, 2010 08:26 AM
soundhd
Oct 13, 2010 08:33 PM
sixpack71
Jul 15, 2009 10:42 PM
