front disc brakes
Old Jan 23, 2013 | 06:50 AM
razalas_89's Avatar
front disc brakes
Have a 69 Roadrunner-don't drive it much in the Houston traffic. Moving to a rural setting and plan on more driving.
Please share with me a good, fairly priced, and complete conversion kit. I would like to spend max. $1000. Is there enough support for an average person to do this on his own?
A few brands to consider and just wonder- do these sellers (Wilwood,Jeggs) mfg. their own components.
Please identify most common mistake on selection and installation process.
Old Jan 23, 2013 | 10:07 AM
I have a big disk brake setup off of a 1974 A body that was the same used on a later B body that will get you the calipers and rotors and such. You will then just need to source a disk brake master cylinder and and proportional valve. Good thing is that I am in Houston also.
Old Jan 23, 2013 | 04:03 PM
bigblock's Avatar
Go with the SSBC kit from Summit Racing. You get four piston calipers,brackets,bearings,seals,rotors,hoses,all for about $850. WAY better than the stock disc set-up.
Old Jan 23, 2013 | 04:04 PM
bigblock's Avatar
If you want discs on the rear PM me for info on cheap junkyard parts.
Old Jan 23, 2013 | 07:14 PM
Chryco Psycho's Avatar
Scarebird is another good option , you can use the drum spindles
1968newport
Mar 12, 2013 06:21 PM
solm96@me.com
Nov 25, 2010 02:47 AM
bruger
Jul 16, 2010 10:14 AM
Rbaisch
Dec 1, 2008 02:17 AM
kunfumark
Mar 7, 2007 09:25 AM
