headlight issue
Old Jun 20, 2010 | 10:00 PM
barelad70's Avatar
headlight issue
hey guys i have a 70 coronet and here is my issue can anyone please tell me why my headlights get very dim when i push my breaks or come to a complete stop and my blinkers wont even blink
Old Jun 20, 2010 | 10:38 PM
1966sportfury's Avatar
A.K.A Bob Dodge
bad alternater or regulater, not charging prperly when theres a load, maybe a short
Old Jun 21, 2010 | 07:54 PM
THE GOOSE's Avatar
i had that problem with my charger it was my regulator. check your voltage with a volt meter or with the engine running, you can take a screwdriver and touch the back of the altenator shaft. if its magnetic your charging, if not have your altenator tested and go from there.
good luck!
Old Jun 22, 2010 | 04:09 AM
dodgenut7's Avatar
had the same problem with my dart changed my voltage regulator and been fine ever since
Old Jun 22, 2010 | 06:12 AM
rdrunner1974's Avatar
Headlights
Read the link article about relays, you may have a regulator or alternator problem but this is for brighter lights.
http://www.madelectrical.com/electrical-tech.shtml
Old Jun 22, 2010 | 09:38 AM
sweeperking's Avatar
If your charging ok while driving down the road and it shows a discharge stopped at idle well, thats characteristic of the classic mopar. You could try bumping up the idle a bit or go with a smaller pulley on the alternater. Probably the only other choice would be a higher output alternater.
19newport72
Mar 27, 2024 06:44 PM
val1550
Jul 18, 2013 12:17 PM
THE GOOSE
Sep 28, 2010 05:36 PM
stazja01
Jan 15, 2009 08:36 PM
raffaplymouth
Jan 20, 2007 01:24 PM
