just picked this up
Old Jan 11, 2009 | 07:04 PM
have you checked the distributor or the spark plug wires?
Old Jan 12, 2009 | 04:01 AM
welcome to the forum first off!
Have you checked to make sure that you have compression? can you smell/see gas in the carb?
66 - I had a single barrel carb on my 78 d200 with a 318. dodge did make them but I will never understand why.
Old Jan 12, 2009 | 05:45 AM
Polaradude's Avatar
Did you do a compression test ?
Old Jan 12, 2009 | 01:00 PM
make sure you have an oil with zinc in it
try to pour some gas down the carb
Old Jan 12, 2009 | 01:48 PM
how long did you crank for?
Old Jan 12, 2009 | 01:53 PM
crank the engine by hand to top dead center, and make sure the distibutor is pointing to the number one cylinder
Old Jan 12, 2009 | 04:51 PM
Polaradude's Avatar
Ya, check timing fer sure
Old Jan 21, 2009 | 07:27 PM
good luck with the rebuild
Old Jan 22, 2009 | 03:36 PM
challenger's Avatar
Boy you got a great find in my book and hope that you can get it going before to long , keep us updated on how the build goes and if you have any problems
Old Jan 31, 2009 | 02:38 AM
Polaradude's Avatar
See if you can return the KBlacks, let them break in someone else's motor.
Old Jan 31, 2009 | 08:14 AM
ya, i wouldnt trust KB pistons
too many people have said that their breaking
Old Jan 31, 2009 | 01:16 PM
Commando's Avatar
I used speed pro for my build, you may also know them as sealed power or trw.
Old Jan 31, 2009 | 03:06 PM
Polaradude's Avatar
Listen to Commando, those in my opinion also are the slugs to use.(forged)
Old Feb 2, 2009 | 09:57 AM
  #26
safest bet with mopars for cams are edelbrock or purple cams
what kind of power are you looking for?
what kind of rear end do you have?
Old Feb 2, 2009 | 02:15 PM
  #29
make sure the cam you choose fits the rpm your gonna run in
im not to good with cam statistics, but im sure someone else here is
gearheadmike
Aug 17, 2011 05:56 PM
djneaman
May 13, 2011 05:24 PM
maxaud
Sep 23, 2010 07:34 PM
79mopower
Nov 13, 2006 08:08 PM
