Mystery fitting leaking oil
Old Dec 6, 2016 | 09:31 AM
1970ccc's Avatar
Hey, I'm new to this Mopar game! I have a '70 Belvedere 2D with a 318. There is a fitting/sensor? located under the vacuum advance at the back of the intake and is covered in oil. What is that?
thanks
Ron
Old Dec 6, 2016 | 12:56 PM
Probably not much help but the only SB I've had oil problems with at the back of the intake leaking........oil!!!!
Old Dec 6, 2016 | 01:38 PM
Drag Pak's Avatar
I believe you mean the oil pressure sending unit. On occasion they will leak at the crimp, or it could be loose. And as mentioned the rear intake gasket could be leaking, and/or the distributor to block seal could be leaking also causing the appearance of a sending unit leak?
Old Dec 6, 2016 | 04:37 PM
Easiest thing to do is replace the oil pressure sender. If it still leaks you know it is the intake manifold. Most use Permatex The right stuff instead of the end gaskets for a better seal.. If it is leaking from the metal dist seal you probably have a bad PVC valve or too much blow by
Old Dec 7, 2016 | 03:47 AM
1970ccc's Avatar
Thanks TV. I'll get a new sending unit. The dizzy seal is dry and the oil seems to be only on the unit. Thanks
ChargerBoy'71
Oct 28, 2010 05:52 PM
ChargerBoy'71
Oct 11, 2010 06:45 PM
jtvisco
Nov 8, 2009 03:38 PM
wrenchn365
Oct 8, 2009 01:20 PM
dzltd02
Oct 28, 2008 08:25 AM
