No Spark
Old Jul 25, 2010 | 04:00 PM
74bbroadrunner's Avatar
Exclamation No Spark
I just put a 440 with and 833 in my 74 plymouth roadrunner and turns out I can't get a spark. I've exhausted all my skills.
I have roughly 6 volts going to the coil, no power to the distributor, I put a new resistor on the firewall(little porsolin thing), didn't make a difference. I don't know if my ECM is bad or not. When I put a test light on the prong on the firewall side of the wires goin to the distributor it sounds like the coil is ticking.
I'm getting frustrated if anyone can help that would be great thank.
Old Jul 25, 2010 | 04:52 PM
6fury4's Avatar
Member
Electronic ignition is voltage sensative, try a fully charged battery. Should have close to 14 volts.
Old Jul 25, 2010 | 08:11 PM
Thanks i will give that a try. If that doesn't work how do I check if the ECM is bad or not?
Old Jul 26, 2010 | 03:50 AM
rdrunner1974's Avatar
spark
You will not have vlotage at the dist. At the coil positive there should be 7-8 volts. Be certain you have the correct ballast resister. The ECU needs to be grounded at the mounting area on the firewall, if you have painted your firewall that could be the problem.
Do you have a schematic for the electronic ignition? If not go to the link to see one. http://www.mymopar.com/downloads/elecignconv.pdf
Ther is more info in the tools reference section of that site.
Old Jul 29, 2010 | 01:14 PM
I put in a new ecu car fired right up. Than it quit, I regapped the pickup coil in distributor and it ran like a champ. Than wouldn't start again, no ac voltage comin from distributor again so I am going to replace the distributor tonite and see what happens thanks for the help.
buttton
Apr 1, 2013 10:00 AM
austin
Sep 18, 2012 12:37 PM
deadkelly
Aug 26, 2011 02:06 PM
1969dart
Oct 21, 2008 04:24 PM
Pfhoenix
Apr 3, 2008 10:44 PM
