Slant six ignition timing
Old 05-10-2017 | 11:34 PM
willem_at_work's Avatar
Hi there,
I have a question about setting the ignition timing on a slant six: Whenever i hook up a timing light and check out the indicator on the flywheel, the engine will only run nicely when the mark on the flywheel is way below the indicating thing. If i set the ignition exactly on the indication, the engine dies immediately. Does anyone know what's going on?
regards. Willem
Old 05-11-2017 | 07:29 AM
Do you have the vacuum discounted from the distributer?
It should be.
willem_at_work (05-21-2017)
Old 05-13-2017 | 01:44 AM
Well, my distributor doesnt have a vacuum advance.
Would that be the cause?
Old 05-13-2017 | 08:20 AM
In this case.... Try setting it with a vacuum gauge and see if that works better.
Old 05-13-2017 | 10:16 AM
Because something is off , distributer or the damper.
Old 05-13-2017 | 10:18 AM
Correct Bob?
Old 05-14-2017 | 06:30 PM
John Van's Avatar
I just love the slant 6, anyway I would check the timing chain. Turn the crankshaft back and forth while watching the rotor in the dizzy to check for too much play. This is common on the 6 with the plastic teeth on the cam.
good luck, john
Crisal53
09-24-2016 03:22 AM
Gorts 5th
12-19-2012 04:52 PM
a.johansson84
05-27-2012 03:30 AM
hatboy2002
06-18-2008 10:05 AM
thekinzuakid247
01-31-2007 06:58 PM
Quick Reply: Slant six ignition timing
