starting problem on 1972 satellite
Old Dec 28, 2008 | 02:54 PM
mopar nate's Avatar
Angry starting problem on 1972 satellite
ok i have replaced my shifter cable on my 1972 satellite its 440 with 727 trans and now it with not start unless i use a jumper button on the starter solenoid i have tried taking the shifter cable back off and pushing the trans into park manually and it still will not fire from inside the car .......i have tried with the cable on and off both in park and nothing so.....im like a dog watching tv i dont know what going on
Old Dec 28, 2008 | 05:48 PM
BuckNeccid's Avatar
Check the wires going to your neutral safety switch, driver's side of your tranny. It may be off the contacts, or just loose. Since you had to work in that area for the cable, there's a good chance that's where your problem is. If not, check the center wire of the harness plugged onto the neutral safety switch... it runs to the solenoid and just plugs on. Could be it's the culprit
Old Dec 28, 2008 | 09:48 PM
mopar nate's Avatar
yea i tried unplugging and plugging it back in. i just think it is in the box on the firewall where all the wires go in but i just need to check the wires so i dono but thanks mopar nate
Gishman91
Feb 16, 2013 11:05 PM
68bird
Sep 10, 2009 03:07 PM
1969dart
Oct 3, 2008 12:34 AM
speedtriple
May 30, 2008 03:45 AM
siliconcrunch
Apr 8, 2008 10:17 AM
