Switching Carbs 73' satellite?
on
I want to swap out my 2bbl Carb for a 4bbl, I'am going to need to switch intake manifolds? Or are there one that will work on the manifold i have? the motor is a 1968 318'. also what is a Reliable affordable carb??
Thanks!
-Dylan
Thanks!
-Dylan
on
Change Manifolds
Dylan - recommendation is to change
If you look on craigslist you can find a lot of SB mopar manifolds for cheap. I really like SB 340 manifolds, they are well rounded. The provided the performance, have a choke riser and are not too much yet not too little. Seems they run about $100
You should be able to find a decent carb as well. Both Holley and Carter provide a Mopar bracket extension for the kick down and the throttle bracket (http://www.summitracing.com/search/?...y%2020-7&dds=1)
Hope this helps
Hope this helps
on
Man out in Arizona, nobody has Mopar parts on craigslist, at least in the phoenix area, lol all Chevy's
Here is a good read that should answer many of your questions.
http://www.allpar.com/mopar/4bbl.html
upgrade 400 2bbl 1973 to high performance 400 4 bbl
Hi everyone!
how upgrade 400 2bbl 1973 to high performance 400 4 bbl? Are necessary to change the intake manifold? Where can I buy a TQ carter 4 bbl carb? and the standart 4 bbl air filter? I must change anything else?
Sorry about my poor english, I'm brazilian
Thank you in advance
R -
Technically, no, you could get an 2 barrel to 4 barrel adapter plate, but you will be much better off with a new manifold.
Also. if you do go to a 4 barrel, be careful with the size (flow rate/cfm), meaning keep it fairly small, like around 600 cfm, unless you plan on doing other things to the motor.
Welcome aboard,
Welcome aboard,
Dtwich90,I have a '73 340 manifold available.
Roneisele, also have a TQ that has been on the shelf for about 15 years, probably needs a rebuild,I will look for numbers if there is any interest in it. PM me for details.
74Runneer
09-28-2021 09:59 AM
AnthonyGW0114
11-23-2011 02:00 PM
440-4x4
08-14-2011 04:46 PM
