1966 Fury III Brake light...
Old May 10, 2016 | 01:44 PM
jumpr71's Avatar
My 66 has a brake light "out". My turn signal works, my running light works, and when I press the brake pedal the left brake light functions but the left does not...any clues? Bulb is new, and tested...
Old May 10, 2016 | 05:31 PM
Dose the left back up light work? If it's out also? Check the ground....
Pull the bulb out and check the green wire for power when the brake is applyed.
If it does the problem is the bulb.... If it has not power, you got a Turn Signal Issue...
Keep us posted on what you find....
Old May 11, 2016 | 07:48 AM
DDodger's Avatar
If you are certain this is the symptom, the problem is right in the turn signal switch.
You can easily check the power going in and out of the switch right at the connector
You can download diagrams and service manuals for free over at MyMopar
Old May 12, 2016 | 05:10 AM
jumpr71's Avatar
Hey all thanks for the help. My issue is in my turn signal switch. I messed around with the turn signal switch while parked, and my brake light started working again. I will get into it this weekend, and replace the switch.
Old May 14, 2016 | 06:17 AM
peter123wallace's Avatar
Did you checked all the connectors for corrosion?
70plumchallenger
Aug 11, 2015 08:26 AM
fury_19
Jun 25, 2012 02:53 AM
mr.300
Feb 12, 2012 11:33 AM
66FuryBoy
Jul 31, 2011 01:37 PM
solm96@me.com
Jul 10, 2010 08:35 PM
