66 fury vip
Old May 25, 2017 | 08:00 AM
MT406's Avatar
66 fury vip
Hey everybody! Jist picked up a sweet 66 fury vip 4dr hard top
Trying to find as much info as possible!!
One big question, it gets vapor lock after running for a while, I noticed right under the fuel line on the side of the head/intake that it is BLOWING AIR OUT??? Never seen air come out, only in? The guy I got it from said it's probably missing a baffle.
Where could I source this part? Im not finding anything online, maybe im not using the correct part name?
Any ideas greatly appreciated!
I am planning to rebuild card and do the intake seals, deck and polish the heads and do the front main seal, go through everything real good so having everything I need befor hand would be a good idea.
Also, I cant figure out how to post pictures? Lol
​​​​​​​Thanks!
Old May 26, 2017 | 09:12 AM
MT406's Avatar
I cannot for the life of me get pictures to post...
If you look at my gallery you can see a couple pics of engine & car
In one of the pics you can see where its blowing air out of the head, any ideas would be awesome!!
Also any help finding the ID on the block? General area to look?
Old May 26, 2017 | 12:21 PM
Welcome to the site:
Go to the "Search" in the top tool bar...
Type How to post pictures and avitars...
Should take you to the how toos...
Old May 27, 2017 | 11:44 AM
70newport's Avatar
If it is a correct 66 motor there should be casting numbers on the left side of the block. If it is a newer 383 68+ they should be on the right side of the motor.
as for the air coming out If I am correct there should be a block off plate on the top. I think that was to heat up the intake temp for cold starts If I am Correct.
Old May 28, 2017 | 02:42 PM
MT406's Avatar
I feel dumb now. LOL
Well here it is. You can see where the air is coming out
Attached Thumbnails 66 fury vip-img_20170526_155939.jpg   66 fury vip-img_20170526_155946.jpg
Old May 28, 2017 | 02:49 PM
MT406's Avatar
I LOVE the magnum 500 wheels!
Attached Thumbnails 66 fury vip-18595427_1602286639812820_3322840451918749207_o.jpg
Old May 28, 2017 | 03:06 PM
No now you have experience.
Old May 29, 2017 | 07:57 AM
No.. Air dose not come out of that hole... Heat yes.. Air No...
Old May 29, 2017 | 02:59 PM
Unless the gasket is bad.
Old May 29, 2017 | 03:18 PM
MT406's Avatar
Yeah there's a decent amount of air blowing out. Enough to blow starter fluid right back at me.
That's how I noticed it, was checking the intake seals and it sprayed me back LOL
I just rebuilt the carb. Anybody ever see one double stamped? I can't make out any #s because there's an old stamp, and some newer looking numbers right on top of each other. It's a Carter AFB 4bbl
I'm pulling the intake right now, got new valley pan and intake seals. Anybody know the torque specs for the intake? Not finding it online and my manual hasn't arrived yet
Thanks for the replies!
Old Jun 5, 2017 | 09:17 AM
MT406's Avatar
No more air leaking out I need to get the heads & intake decked, it's pretty rough around that port. Little bit of rtv sealed her up though. HUGE power gain
Old Jun 5, 2017 | 09:35 AM
Glad things are working as they should!
MT406's Avatar
Also, does anybody know of any good reads in regards to rear diff? Think mine is about toast & I would love to replace & upgrade but I'm not all that knowledgeable in that area. Anything that would help help me understand the ratios & parts would be awesome. Can never learn enough, right
Old Jun 5, 2017 | 09:46 AM
Look at Curries or Toms differential websites , I'm sure there's plenty others, one of them will have what you want.
GG1
Sep 1, 2016 12:02 AM
mattiedaddie
Jan 23, 2012 04:53 PM
fury1966vip
Feb 19, 2009 12:41 AM
Baluchitherium4
Dec 8, 2008 09:47 PM
steve28529
Jun 16, 2007 08:13 PM
