Cracked Heater Control Valve... AGAIN!
Old Jun 19, 2021 | 03:23 PM
Boompy's Avatar
Greetings Crew Members.
I've been enjoying my 1969 Chrysler Newport Custom. Lately The Ghost has been getting 50 smiles per gallon!
Then I noticed a puddle under the car. Traced the leak to my vacuum operated heater control valve. I replaced the original CRACKED valve with a NOS unit 18 months ago.
So what are my options? I'd be interested in a replacement metal unit but I'm not sure what will work. Once bitten twice shy about trying another 52 year old "new" old stock part. Interested in your thoughts...
​​​​​​​Regards, Captain Chrysler
Old Jun 20, 2021 | 09:37 AM
Oh No... Not again !!!!
Old Jun 20, 2021 | 02:26 PM
Boompy's Avatar
Yup, I felt the same way!
There has to be a 4 port vacuum operated heater control valve that is built better. At this point I don't care if it's a Ford part!
Any suggestions RacerHog?
C.C.
Old Jun 21, 2021 | 08:26 AM
Shoot us a photo and will see what we can come up with..
If I recall correctly, That one is mounted under the hood of the car? and is operated by one hose?
Old Jun 21, 2021 | 03:31 PM
Boompy's Avatar
You are correct, Sir!
Here's a picture of the mystical unit. I plan to cob together a bypass tube, 3/4" to 5/8" so I can drive The Ghost while I locate a suitable aftermarket replacement. I appreciate your help finding the mystery part.
Warm regards, C.C.
Old Jun 27, 2021 | 07:04 AM
Did not find any except on e-bay....
Everhot #H1949 / looks like a good replacement
OE # 2936490
check them out
Old Jun 27, 2021 | 10:59 AM
Boompy's Avatar
OE # 2936490
check them out
THANKS RacerHog!
I've seen these before on other MoPars with AC. I'm a little gun-shy about another 50 year old part but it is metal, not bakelite that cracks.
I installed a plastic heater hose connector so I'm back on the road. Shouldn't need heat for many months.
I thought about contacting the folks at "Graveyard Cars" to see what they use. They might have a source for the same product. Thank you for your help!
Regards, C.C.
Old Jun 27, 2021 | 11:13 AM
You mite try the local parts store.. and see if you can get a metal vacuum one ether 5/8 or 3/4. In size…
then just hook it in line with only one side.. should work it you put it on the input side.
just a suggestion..
These fit like a 1967 Mercury..
Old Jun 27, 2021 | 05:42 PM
Boompy's Avatar
just a suggestion..
Thanks for your help RacerHog.
I'll let you know what I come up with, might help the next person.
Regards, C.C.
stilllearning6
Oct 1, 2014 08:04 PM
dgbcharger
Jul 21, 2014 03:26 PM
cholette
May 15, 2012 11:12 AM
recondotexas
Apr 14, 2011 07:57 PM
opostal
Oct 30, 2009 08:01 PM
