Lowering a '67 Fury 1
Old Jun 23, 2010 | 01:39 PM
67furywagon's Avatar
Junior Member
Wondering if anyone has experience with lowering a '67 C-Body (or maybe there is a previous thread you can point me to).
I was considering 3" blocks for the rear, and then cranking down the torsion bars 2" in the front (which should level it out). Is this a reasonable drop? Any pointers or gotcha's I should keep in mind?
Thank you!
Old Jun 23, 2010 | 05:32 PM
Sangetsu's Avatar
Keep in mind that you may not be able to properly adjust camber in the front wheels if you lower the front by that much, and that you might get some bottoming-out of your suspension when going over larger bumps and potholes.
I had a couple cars which I lowered, and I did like the way they looked. But lowering them also had the effect of worsening their handling characteristics (which are not spectacular to begin with). If your car is not a daily driver, just something you play with on Friday nights or the weekends, lower away. But if you do drive the car a lot, go easy on how much you lower it.
Old Jul 4, 2010 | 09:33 PM
That's how I lowered my '68, and the thing turned out awesome. i absolutely love the look of those big boys in the weeds.
Old Jul 4, 2010 | 09:34 PM
also, check this thread out:
https://moparforums.com/forums/f11/l...-68-fury-4390/
raindance654
Apr 27, 2015 04:51 PM
patricklyle77
Sep 13, 2010 08:45 AM
kgarber
Aug 30, 2009 05:08 PM
Monacoman
Aug 13, 2009 10:00 PM
patricklyle77
Jun 13, 2007 09:47 PM
