Q on New Yorker 1969 engine, trans, diff.
Old Apr 2, 2019 | 03:30 PM
440carbon's Avatar
Is the 69 RB440 a good engine to build up for mild-moderate performance? I have a 69 New Yorker I want to put the
engine, trans and rear end in a 69 Dart.
Old Apr 2, 2019 | 04:46 PM
The 69 440 should have a steel crank and 906 heads if your not using aluminum aftermarkets.
Old Apr 2, 2019 | 08:18 PM
Can fit with the rite hardware.... But the differential is not a good swap. it's to wide.
Old Apr 2, 2019 | 08:24 PM
You can narrow the housing and buy aftermarket axles. 🙂
Old Apr 3, 2019 | 06:55 AM
Yep...
Old Apr 6, 2019 | 05:22 PM
440carbon's Avatar
will the axle housing come out of the differential to allow shortening or do you have to cut it and weld it back together?
Old Apr 6, 2019 | 05:26 PM
440carbon's Avatar
Also, I know there are a handful of differentials out there. Are the 3rd members transferable among the 741,742, 489 differentials?
Old Apr 6, 2019 | 06:21 PM
If you asking if you can swap the drop outs yes you can but there are different yokes.
Old Apr 7, 2019 | 07:53 AM
Yes... And Or Flange Ends
Old Apr 7, 2019 | 07:55 AM
And add what Iowan said Pinion Splines...
KcarKrazy
Dec 12, 2017 09:05 PM
ermracing
Mar 6, 2016 05:57 PM
Rodney Collins
Dec 12, 2015 12:56 PM
Jon68gtx
Jul 12, 2015 08:13 PM
fpereira23
Jan 26, 2009 06:49 PM
