73 Cuda Dash Replacement
Old Mar 31, 2011 | 08:49 PM
mek2280's Avatar
I need to replace the dash pad in my 73 Cuda. Does anyone have an exploded diagram or set-by-step instructions for this procedure? Thx
Old Jun 21, 2011 | 12:10 AM
3404speedcuda's Avatar
no, but I just did mine, put a dash cap on, and it wasnt that bad, I would say the hardest part is the wireing, getting it back correct I would mark all wires that arent obvious, anyway its only 5 or 6 bolts/screws 4 from the defrost vents inside top by the windshield and 2 bolts 1 by each kick panel on the sides also found a brace about dead center behind the ash tray and I still cant find where to bolt it to now
hope it helps, just dive in its not as bad as you have herd.
Old May 12, 2012 | 07:52 AM
mrbill426's Avatar
It helps to have a friend with you, it can be a handfull trying to lift it out alone.
Cracocuda
May 1, 2014 04:54 PM
Nu2MOPAR
Aug 10, 2013 10:38 PM
Duster703404
Nov 16, 2008 06:00 PM
64fury
Mar 6, 2008 06:57 PM
texasmoparman
Apr 18, 2007 09:50 AM
