73 Cuda Dash Replacement
Old 03-31-2011, 08:49 PM
mek2280's Avatar
I need to replace the dash pad in my 73 Cuda. Does anyone have an exploded diagram or set-by-step instructions for this procedure? Thx
Old 06-21-2011, 12:10 AM
3404speedcuda's Avatar
no, but I just did mine, put a dash cap on, and it wasnt that bad, I would say the hardest part is the wireing, getting it back correct I would mark all wires that arent obvious, anyway its only 5 or 6 bolts/screws 4 from the defrost vents inside top by the windshield and 2 bolts 1 by each kick panel on the sides also found a brace about dead center behind the ash tray and I still cant find where to bolt it to now
hope it helps, just dive in its not as bad as you have herd.
Old 05-12-2012, 07:52 AM
mrbill426's Avatar
It helps to have a friend with you, it can be a handfull trying to lift it out alone.
Cracocuda
05-01-2014 04:54 PM
Nu2MOPAR
08-10-2013 10:38 PM
Duster703404
11-16-2008 06:00 PM
64fury
03-06-2008 06:57 PM
texasmoparman
04-18-2007 09:50 AM
Quick Reply: 73 Cuda Dash Replacement
