73 Cuda Question
Old 03-21-2009 | 03:15 PM
roadrun383's Avatar
Junior Member
I would look into Keisler. I think you can get everything you need to convert it over right from them
Old 03-21-2009 | 03:55 PM
Polaradude's Avatar
check out Tremec.
Old 03-22-2009 | 11:52 AM
johnthegoalie's Avatar
thinkin with me dipstick
keisler has an entire kit to do the conversion using the tremec transmissions.
http://www.keislerauto.com/
Old 03-22-2009 | 12:57 PM
Richmond makes great trannies if you have all the other parts to do the rest of swap.
Old 06-09-2011 | 09:38 AM
mek2280's Avatar
I recently purchased a 1973 Cuda with a worked 440 and 727 Torqueflite transmission. It is equipped with a 6-speed add-on device from a company called Gear Vendors (www.gearvendors.com). It works very well with the manual valve body installed. I'm producing about 550 hp at the rear wheels and I have a shift kit that hits fairly hard and the GV unit performs flawlessly. The way I have the GV unit configured, I have the standard 1st, 2nd and 3rd gears with an automatic overdrive that activates at about 50MPH. The overdrive drops about 700 rpm so I'm sure I'm getting at least 5mpg at highway speed now, lol. Good luck! Hope this helps!
Old 01-05-2012 | 02:57 PM
Joe's challenger's Avatar
I used Hurst Driveline's TKO 600- very similar to Kielsler however Hurst had a quicker delivery and support was top notch. Their elite kit has everything from auto to manual. You will need to weld a Zbar if using a manual clutch, unless you want a hydralic system. Good luck.
aarcuda7954
09-07-2014 06:58 PM
splitbenchucodeauto
10-30-2012 07:48 AM
cudaracer
08-12-2011 03:10 PM
Quick Reply: 73 Cuda Question
