74 barracuda
Old Mar 14, 2009 | 07:57 AM
Crazy4Carz.Com's Avatar
Other than the obvious ( radiator, motormounts etc) the only difference was the torsion bars. They were sized to match the engine size/weight. They are all interchangeable, just get whatever size you want. The Hemi cars used the 6 cylinder bars for the benefit of weight transfer (weaker bars) the heavier the bar the stiffer the ride but the better the handling. Good luck with th build I built those in the past. Good starter project just take your time. If you have other questions on the build post here or on www.Crazy4Carz.Com
Old Mar 14, 2009 | 01:35 PM
Crazy, are all the A-body torsion bars interchangeable? I'd like better handling from my Valiant and don't mind a stiffer ride. I've along got a slant 6 in it too.
Old Mar 15, 2009 | 04:11 PM
challenger's Avatar
as far as i no they are 78 the A body's are 35.750 inches long and the E-B bodies are 41.000 inches long i would go with the .890's if you are leaving the 6er in
Old Mar 15, 2009 | 04:15 PM
challenger's Avatar
sorry 74 cuda i would go with the E body ones (TB) with the same at .920 for that good ride , i have the .960's in my challenger but never seen any differance in the handleing sonds like it is going to be a sweet ride
Old Mar 18, 2009 | 06:19 PM
There are different "spring rates" for the torsion bars and yes! you can install big block abody torsion bars and it will handle like crazy. Also add an adco sway bar and it will be amazing. This is the setup we had on the One lap of america dart.
ProEmaster
Feb 11, 2008 11:23 AM
ruffinracin121
Nov 20, 2007 06:53 AM
ruffinracin121
Oct 29, 2007 08:32 PM
danuwells
Aug 30, 2007 11:45 AM
smitchell
Jun 11, 2007 11:40 AM
