Any Help Removing Heater Fan
Old Sep 11, 2012 | 03:15 PM
gregsgs@yahoo.com's Avatar
Hi Everyone we its time to fix the heater fan. Can anyone tell me were to start or have a diagram of the parts. Its a 70 cuda with out AC I don't no were to start someone told me it very in hard to do. Any help would be GREAT thanks
Old Sep 11, 2012 | 08:11 PM
moparted's Avatar
you have to remove the entire heater box assembly
Old Sep 12, 2012 | 08:23 AM
Do you know were to start with that
Old Sep 29, 2012 | 09:49 AM
Chryco Psycho's Avatar
drain the coolant , remove the heater hoses , remove the glove box liner , there is 1 hidden bolt insode the vent on the right side , it is a hook that holds the heater box up , loosen the bolt & carefully unhook it then undo the 3 - 7/16 nuts around the heater motor in the engine compartment & sldie the heater box back into the car now remove the vent & heat cables & remove entire heater box
kiwi
Jul 26, 2011 09:39 AM
Cazbah362
Jun 12, 2011 01:05 AM
mytracy
Dec 29, 2010 08:20 PM
JLanzino
May 1, 2009 06:58 PM
gilesie
Jul 14, 2008 02:29 AM
