Breaking up
Old Mar 4, 2017 | 12:44 PM
Gregg123's Avatar
Breaking up
Hello ,I have 340 ralley Challenger,now it has 440 4spd usded stock Elc ignition for a 73 car my problem is car runs poorly ,feels like ignition problem everything is new motor is 1976 rebuilt , Iwas checking voltage from battery to ballast resistor only have 10 .4 volts ,wondering if it needs a full 12 , also swapped out control box car still acts the same . car also doesn't run Well with no load while driving ,if your on the gas it will stay running , but it feels like it's struggling to run ,like it's breaking up ,Vacume is around 10 pulls up to 15 to 18 when you rev it , I also changed the Distributor cap , thought maybe it had hair line crack. Any ideas ???thanks Gregg
Old Mar 4, 2017 | 04:30 PM
Perform a Compression test... Lets see what that comes up with.....
My own theory is "You cant tune up and engine that has bad compression"..
If that comes out good. Then a tune up might be in order.
Check for Vacuum leaks also...
Hope this gets you started Greg...
Old Mar 4, 2017 | 06:19 PM
How many volts at the coil?
Old Mar 20, 2017 | 05:04 PM
Gregg123's Avatar
Old Mar 20, 2017 | 05:05 PM
Gregg123's Avatar
Thanks motor only has 50 miles on it ,just really missed something in the set up thanks Gregg
Old Mar 22, 2017 | 08:32 AM
OK....Check for vacuum leaks.... Try resetting the timing.... and as Iowan said. Make sure you have a good coil and voltage to it...
One other question comes to mind? Did the car ever run rite after the rebuild or within the 50 miles?
Keep us posted...
Old Mar 23, 2017 | 05:19 PM
Gregg123's Avatar
Keep us posted...
Well running better , this is a new one for me wiper motor must have a short ,it was drawing down my voltage it was hot just plugged in ,accidentally leaned on it checking voltage on firewall thanks for all the help Gregg
Old Mar 23, 2017 | 07:21 PM
Must have been a short
Old Mar 24, 2017 | 08:38 AM
Wow... Now thats an odd one for the book !!!! Glad you found it...
Old Mar 25, 2017 | 01:14 PM
Gregg123's Avatar
Well tryed again to get car timed no luck the motor wants 38 just to run if you try bringing it back say around 20 it just dies ,we went and checked the valves they are adjustable but seemed fine ,I will try a different carb Sunday ,then I was going to try old school points set up I have an older points distribotor,just to see if it runs an better , last shot I'll have to pull the front of the motor apart ,maybe there's something wrong with timing chain , never had a motor need so much timing to run bought this 440 as a rebuilt motor no idea what cam put it seemed to be all intact
Old Mar 25, 2017 | 02:40 PM
Also Check for vacuum leaks.....
You could be on to something with the cam timing. Someone might have installed it wrong...
raycan2
Aug 21, 2013 10:18 AM
zrt1000
Oct 23, 2011 06:20 AM
BuckNeccid
Apr 27, 2010 10:16 AM
72sat
Dec 30, 2009 01:56 AM
