Fuel Related Problems??
Old Aug 21, 2008 | 09:37 PM
challenger's Avatar
Hey xody the 1406 is a 600 cfm Square-Flange ec/non egr carb so make sure the intake you have is for that carb as in single plane vs dual plane and i would turn the idle mixture screws in all the way (easily) and back off turn and a half then start and hopefully it will run and turn one screw out slowly till the idle increases then stop and do the same with the second one ( in no order ) you might have to adjust the idle screw for proper rpm after your done but try that first as edelbroks usually comes right out of the box ready with just a turn or so ..... you might have to change the metering rods to a smaller diam: to get more fuel flow as the 600 might just be a bit small for the 440... the stock MR are .075 x .047// change to .070 x .042 if you need to
Old Sep 23, 2008 | 05:37 PM
Commando's Avatar
Edelbrock recommends that carb (14064 is what I am putting on mine) for that engine, as I am putting their performance series on my 440, I would adjust the carb if need be, maybe jet it.
I assume you have a manual choke, from the way you say it, if it idles and you push the choke in does it die?
You may have a vacuum leak, are all the vacuum lines hooked back up? Sounds similar to the problem I just solved.
Old Sep 25, 2008 | 07:22 PM
what about the vacuum advance connected to the distributor?
Old Sep 26, 2008 | 07:44 PM
Red Devil's Avatar
Little Demon
I have a buddy who had the same problem on his truck and it turned out to just be a vacuum line. But I would deffinetly try adjusting the carb like challenger reccomended, It can't hurt.
Old Sep 26, 2008 | 08:17 PM
Commando's Avatar
When you shake the pcv valve does it sound like a spray can, meaning is it clean and unclogged?
I assume you have a "Christmas tree" as I have heard it called by mechanics, the thing in the intake that feeds the power brake booster, and whatever else that hooks to.
xvodysseusvx
Jun 25, 2018 04:38 PM
labradorian70
Oct 21, 2015 07:04 PM
Ray W.
Aug 26, 2015 08:54 PM
Drakovich
Nov 28, 2011 04:17 PM
Leem
Sep 21, 2010 07:42 PM
