Winter options
Old Aug 2, 2016 | 06:11 PM
rustyshackleford426's Avatar
Winter options
This winter I was planning on working on my 1973 Challenger. I have two things in mind work on the motor that is in it (not original) a LA 360 with J heads and an edelbrock torker 340 or swapping the motor for a 5.9 magnum. If I went with the magnum I would put an RPM air gap intake on it to make it carbureted. If I went 360 I would put a cam in it and stall in it and maybe a RPM air gap as well. Is there any other suggestions I want to keep it fairly cheap. Also I plan on running it in hot rod power tour so reliability is a factor. Thanks!
P.S. I know that the torker 340 is supposed to be bad and it's a single plain but I can't tell a difference from the performer I had because I have 3.91 sure grip.
Old Aug 3, 2016 | 02:19 PM
The Sky is the limit..... Go with what fits the budget.... I say...
Just my 2 cents
Keep us posted....
Old Aug 3, 2016 | 02:55 PM
Budget?
Go with the 360 you have.
Old Mar 30, 2018 | 04:25 AM
ZEN357's Avatar
Yeah, I'd go with the 360 you have and build it.
Old Mar 30, 2018 | 06:56 AM
Archer's Avatar
rusty -
Agree, stay with the 360 (just personal opinion). While e a dual plane intake will give better street performance, with 3.90's the Torker won't be an issue, and if it is, you can correct the problem with a 1", 4 hole spacer. Been doing that for 10 years now, but mine is on a 440. Look into good mid range cams (3k - 6k) , usually staying below the 300 (total) duration / 500 lift will work. Comp Cams are pretty popular.
Jan 11, 2011 03:05 AM
Crazy4Carz.Com
Dec 28, 2010 12:07 PM
Dec 28, 2010 07:43 AM
John Van
Dec 22, 2009 03:07 PM
deadkelly
Oct 15, 2009 05:58 AM
