Blower issues...anyone else?
Old 07-02-2011, 11:46 AM
Streetkitcar's Avatar
So my blower motor only blows on high, the "fan speed" switch is useless. Interestingly, when I pull the connector to the blower switch, fan keeps blowing (on high of course) AND the fuse holder for the blower fuse has begun melting and gets so hot it burned my finger tip when i pushed the fuse for a split sec.
Anyone experienced similar with one speed fan and hot fuse.....? As always, Thanks!!!!
Old 07-02-2011, 10:49 PM
This is a classic case of the resistor needs to be replaced. When the blower motor resistor gives up, power is sent through it so that the fan will still work but since there is no resistance from the resistor, the blower will only work on high.
Old 07-03-2011, 05:33 AM
Thanks! now I just need to "find" that resistor!
Old 07-03-2011, 08:28 AM
fivepoint's Avatar
Not sure about your vehicle but I have found many GM cars and trucks mount the resistor near the blower motor with the resistor coils placed into the blower airstream to keep them somewhat cooler. I have never had to locate one on the better branded vehicles yet.
Old 07-03-2011, 08:43 AM
These resistors are mounted INSIDE the airstream on ALL cars I have ever seen to cool the resistor. So it should be somewhere on the blower/ heater box
I'm not sure in your case that the resistor is the ONLY problem. Seems to me that if the switch will not kill the motor, then the switch has failed internally
Old 07-03-2011, 01:59 PM
Thanks all! Interestingly, even when I pull the connector from the back of the switch when the A/C (or fan) is on, nothing changes, still blows on high. I'll look for that little bugger in the mean time. This poor car suffers from random electrical issues, too many little hands with tools..........
ucfierocharger
07-10-2011 01:02 PM
Monaco383
08-22-2009 09:01 AM
07-23-2009 02:33 AM
johnberetta
02-27-2009 02:20 PM
Doc
02-19-2009 03:28 PM
Quick Reply: Blower issues...anyone else?
