control arm bushing sleeves!!
Old Jul 8, 2009 | 09:03 AM
I'd give PST a call and ask what gives. They should have included them. You can always try a parts store or speed shop. They will probably have to order them though.
Old Jul 8, 2009 | 04:59 PM
theomahamoparguy's Avatar
are you talking about the inner sleeve on the control arm stud or the outer one that slides into the control arm {larger}
Old Jul 8, 2009 | 05:09 PM
Morrigan_Aria's Avatar
Hell kitten
Did you order the polygraphite super kit?
Per the website http://www.p-s-t.com/pc-3771-159-ply...r-1970-76.aspx, "NOTE: Polygraphite® Lower control arm bushings not available, O.E. rubber type supplied with kit." Also, "Add a centerlink or pitman arm, rear control arm bushing set, torsion bars or rear leaf springs to your Super Front End Kit order and SAVE! "
Old Aug 18, 2009 | 05:37 AM
MyDodgeDip's Avatar
Junior Member
I did a set on a diplomat recently, parts store had them in stock. you could always order a cheap set and gut the rubber from it.
btberte
Oct 26, 2013 05:07 PM
Oneder07
Mar 18, 2011 02:18 AM
dboland
Jan 2, 2010 10:06 PM
stanhope55
Jun 19, 2009 02:04 AM
upnorth52
Oct 23, 2008 09:07 PM
