Slant 6
Old Mar 22, 2011 | 06:25 PM
Tommy Lee's Avatar
Slant 6
Hey I broke the oil sending line and lost my oil. Shut it off as soon as I heard the lifters. Put in new oil, and when it first starts sounds perfect but after couple minutes you can hear a light sounding knock deep in. If you excelerate it gets louder. A friend said if it starts, and has oil pressure which it does up to almost 40lbs, that it's just a rod bearing and I just need to put rod bearing in it and it will be fine . ??????
Old Mar 23, 2011 | 02:44 AM
If it is a rod bearing then one of them probably spun which means pulling the oil pan and wiggling each one to see if you can find which one is loose. If that doesn't work, then you will need to pull each cap. Depending on the damage, it might be as easy as an over sized bearing or as extensive as replaceing the rod and crank. It's hard to tell without pulling the oil pan.
Old Mar 23, 2011 | 12:11 PM
Tommy Lee's Avatar
slant 6
Thanks for your information.
nealkal
Aug 30, 2008 04:12 AM
hatboy2002
Jun 18, 2008 10:05 AM
1980b100van
May 2, 2008 09:53 AM
patricklyle77
Jun 14, 2007 10:42 AM
thekinzuakid247
Jan 31, 2007 06:58 PM
