61 station wagon help!!
Old Feb 27, 2011 | 07:03 PM
KC51's Avatar
Long story short. Got this station wagon for free from a family friend. It has the 318 with pushbutton. My question is...will a newer 318 bolt up to this trans?? The reason im askin is because the 318 in it now is huge compared to a newer one. Thanks in advance!!
Old Feb 27, 2011 | 07:21 PM
MercuryDon's Avatar
The 318 Polysphere is a good engine. It is basicly a Semi Hemi. That is why it is larger than a 318LA. The down side is there are not alot of aftermarket performance parts for one. Unless your going to race it, Id leave it as is. There are multi Carb manifolds and stuff out there if you watch Ebay ect. Offy makes some stuff for them I believe.
Old Feb 27, 2011 | 08:02 PM
KC51's Avatar
Well the lady told me it burned about a quart of oil a day lol so id rather pull it and put a newer 318 in and rebuild this one for my 40 dodge rat rod.
Old Feb 27, 2011 | 08:19 PM
MercuryDon's Avatar
I could be wrong but I think the trans bolt pattern is different.
Old Feb 27, 2011 | 09:12 PM
KC51's Avatar
I read in another forum on here that it is?? i just want to be for sure before i go buy another engine.
Old Feb 28, 2011 | 06:09 PM
mr340's Avatar
The poly and the LA have different bell housing patterns, and do not interchange.
Old Mar 2, 2011 | 11:54 PM
KC51's Avatar
man that bites...maybe ill just replace the trans too. but id really like to keep that pushbutton...
Old Mar 3, 2011 | 01:39 AM
1966sportfury's Avatar
A.K.A Bob Dodge
no but yes one bolt will not line up, done it a 65 dodnge 3/4 ton and a 66 sport fury
Old Mar 5, 2011 | 12:19 PM
D Dodge's Avatar
Like to see some pix of that wagon!
Old Mar 22, 2011 | 11:31 AM
KC51's Avatar
heres some. and one of my 40 dodge
Attached Thumbnails 61 station wagon help!!-sspx0005.jpg   61 station wagon help!!-sspx0006.jpg   61 station wagon help!!-sspx0007.jpg   61 station wagon help!!-sspx0008.jpg
Old Mar 22, 2011 | 03:25 PM
bboogieart's Avatar
Nice rides both. I would run that wagon just the way it sits, body wise. Maybe wide white walls on red rims with chrome lugs and a center cap. I like the patina and being as you are building a rat rod I guess you do too. You should be able to find a 318 or better a 360 with the trans for little investment. There is a company called Imperial Conversions that sell kits to install newer trannies in cable shift cars wich is what the push button is. I hear they are not cheap. Being as you already have the cable shift trans you might be able to fab up something to make it work. maybe swap valve bodies(?) In any event good luck and have fun.
Old Mar 23, 2011 | 12:30 PM
KC51's Avatar
i had planned on it but got bored and started sanding it already
Old Mar 23, 2011 | 12:32 PM
KC51's Avatar
ill prolly just end up putting a newer 318 or 360 and trans in it. Along with a better rear end. and some disks up front would be nice. that old poly will prolly end up in the rat! Heard you can put hemi heads on it. How much work would that take?
Old Aug 6, 2012 | 03:30 AM
benjoM's Avatar
Station wagons are mainly boring, almost as bad as minivans. However, numerous car corporations are coming out with sporty wagons. Hot station wagons and “shooting brakes,” essentially the exact same thing, are starting to get really popular. A personal loan will help you pay for your car payment this month.
Gus Johnson dealership
Old Aug 6, 2012 | 01:30 PM
lou3500's Avatar
That thing is awsome i agree run that thing just the way it is stop sanding rebuild the engine slap on some chrome reverse rims and white walls lower it a little an go.
Old Jan 17, 2013 | 11:24 AM
rockerarm's Avatar
318 swap
I'm not so sure thats true. A friend just swapped a 360 into a 64 Dodge using the 64 cable trans. The original engine was a poly 318 which should have the same pattern as the 60 poly 318...
Ya need to check a little further, I always thought the poly 318 and later LA engines would interchange.
Old Jan 17, 2013 | 11:31 AM
rockerarm's Avatar
[QUOTE=benjoM;89807]Station wagons are mainly boring,
Well...... your sure entitled to your opinion..... But station wagons, espically vintage wagons, have more character then most anything other then a convertible. My guess is you've not been around an old wagon much. Stop and take a gook look at one sometime, It dosen't make much difference what kind. The fun is only limited to your imagination.
Old Dec 11, 2018 | 08:40 AM
KRUSTY's Avatar
Any updates pn the wagon?
Dustin Parry
Apr 10, 2017 07:28 PM
RacerHog
Oct 20, 2013 08:54 PM
big99diesel
May 9, 2013 05:58 PM
pbpunisher
Dec 6, 2008 11:08 AM
