2009 Ram 1500 5.7 MDS - weird #5 misfire problem
Old Apr 30, 2024 | 11:08 AM
cuda341's Avatar
Question 2009 Ram 1500 5.7 MDS - weird #5 misfire problem
(I posted this on Ram Forum as well so please ignore if you've already seen it.)
I have a weird thing happening at 135K miles, with a clean well-maintained, original-owner 2009 Ram 1500 Hemi MDS. It’s actually two things that are probably related:
  1. After a cold start, it runs fine. I drive about 1 minute and if/when it kicks into eco/MDS mode, it runs poorly (95% sure due to cyl #5 - see below) until I either pull over and turn off the ignition completely, and restart, or until it warms up over ~165F or higher. This NEVER happens if I start out in Tow/Haul mode or with shifter in a lower gear i.e. 5th, in order to keep it from going into eco/MDS mode until warmed up (or over 165F). Once it’s warmed up, I can use eco/MDS mode just fine, and it purrs along great – like new,
  2. BUT under normal operating temp, if I put relatively heavy throttle into it, typically on the highway, somewhere between 3-4K RPM, it throws a P0305 #5 cyl misfire code. When I let up, the light usually goes away pretty quickly. But this will repeat fairly consistently under heavier throttle, and when it’s occurring, I can usually feel the roughness until it clears.
This original 5.7 has new spark plugs and I tried swapping the #5 coil pack with a new NGK, even though the original still looks new, as do all the rest. Since turning off the ignition and restarting seems to clear either condition, it makes me think this is computer related. The code is always #5 cyl, and she doesn’t seem to be burning any oil or coolant (via head gasket), so other than possibly the injector, I’m still scratching my head at this. If I remember to turn on Tow/Haul or keep it out of eco mode until she warms up, as well as take it easier when passing or using the on-ramp, she runs fantastic like a sewing machine all day long. No tick noise - ever. I’d love to get thoughts on this and what I can try. Thanks in advance!
Old May 1, 2024 | 10:42 AM
PCM Upgrade / Reflash would be my guess since you can fake it out with the tow switch…
Thats what leads me back to the PCM has a defect in it some place!!!
Old May 1, 2024 | 03:13 PM
cuda341's Avatar
Well, I can clarify that condition 1 in my initial description only happens when MDS is not disabled, so Tow/Haul will prevent that. Maybe the PCM is a factor there?
In condition 2, I tend to get the misfire code regardless of tow/haul being on or off, under higher RPMs/acceleration. If I never put my foot into it, day to day, I never get the misfire described in 2. But I also feel like (and hope) it's computer related.
Old May 1, 2024 | 06:40 PM
Couple things you mite look at with a scan tool....
1. Make sure the system is inactive when you mash the throttle
2. Take a look at the injector pulse width and see if is different than the rest.
3. Looks at that cylinder and compare it with the other cylinders on a lab scope parade patten.
Old May 7, 2024 | 02:26 PM
cuda341's Avatar
Also, the fact that shutting off the ignition all the way before starting it back up, seems to make it run smoothly again points me back to the computer/PCM.
Aedan
Dec 22, 2022 10:25 AM
trc29
Jul 19, 2022 09:08 AM
geoffreyweber89
Dec 15, 2017 11:39 PM
Jayman55
Jun 7, 2012 11:13 AM
05ramjsp
Apr 19, 2009 03:45 AM
