85 Ram Changing to soon
Hi there, I've got an 85 Ram with a 360 and 727, it changes gear extremely fast and once it's in third its very sluggish and doing only about 10mph I have to manually pull it back into second to get it moving faster, can you change the 727 externally to make it hang onto the gears longer
It sounds like something needs to be adjusted. Make sure that the kickdown is adjusted properly and check the band adjustments. Other than that, it sounds like something internal like the valve body.
rcknrolfender79
Sep 9, 2010 07:01 PM
