85 Ram Changing to soon
Old May 16, 2010 | 10:40 PM
Blownvh's Avatar
Junior Member
Hi there, I've got an 85 Ram with a 360 and 727, it changes gear extremely fast and once it's in third its very sluggish and doing only about 10mph I have to manually pull it back into second to get it moving faster, can you change the 727 externally to make it hang onto the gears longer
Old May 17, 2010 | 04:20 AM
It sounds to me like you will need to adjust the kick down linkage.
Have you serviced the tranny at all lately?
Old May 17, 2010 | 01:24 PM
Blownvh's Avatar
Junior Member
kick down does work if you really punch the pedal but other than that it wont change down by itself when to press the pedal
Old May 18, 2010 | 03:24 AM
It sounds like something needs to be adjusted. Make sure that the kickdown is adjusted properly and check the band adjustments. Other than that, it sounds like something internal like the valve body.
Old May 21, 2010 | 06:53 PM
will d's Avatar
i believe that what you are thinking is a kickdown linkage is actually what tells your whole transmission when to shift. i would adjust it
zrt1000
Dec 20, 2011 09:34 AM
blue 68 gts
Dec 19, 2011 06:25 PM
Jbalz
Sep 30, 2011 06:14 PM
dodgebuzz
Sep 16, 2010 09:13 AM
rcknrolfender79
Sep 9, 2010 07:01 PM
