18 Durango SRT Antifreeze smell
Old Jan 30, 2023 | 03:49 PM
DMN KLR's Avatar
Angry 18 Durango SRT Antifreeze smell
We have an '18 Durango SRT that smells like anti-freeze after it gets to temp, but is never low. We don't have any leaks from radiator or heater core, no leaks underneath or through the exhaust. We've had it back to the dealer several times and they keep changing different engine components with no success. Anybody else with ANY 392 have this issue?
Old Jan 30, 2023 | 06:17 PM
fivepoint's Avatar
I had a Ram 2500 that did had that too. Never had to add coolant ever. I was told that the coolant hoses gave off that odor. It never smelled when it was cold. I noticed it most often when I got to work in the morning and got out of the truck.
Old Jan 30, 2023 | 06:51 PM
DMN KLR's Avatar
Angry Anti freeze smell
Thanks for the reply. Thats interesting, but you'd think that anything that soaks through something would "bleed" out. Mine doesn't smell until it's been warmed up. Mostly it just smells outside, but after some road miles it will smell inside too, like the heater core leaks. Did you get your problem cured or do you still have it?
Old Jan 30, 2023 | 07:44 PM
xaza's Avatar
Possibly overheating and pushing into overflow and the smell comes bleeding out there with no actual fluid loss?
Old Jan 31, 2023 | 06:04 AM
Kuvasz101's Avatar
My friends and I have experienced similar smells on different vehicles. My brother in-law's 454 boat engines smelled as described all without leaking coolant. I pinned pointed it in these different situations to the exhaust which is burning off ethanol (alcohol) smelling like anifreeze. This has been over a course of many years and still no coolant leaks, but still the ethanol smell which is more noticeable on startups.
Old Jan 31, 2023 | 08:29 AM
fivepoint's Avatar
I have since replaced the truck but, I just got used to the odor. I never smelled it in the cab. The truck never overheated and I never had to add coolant.
Old Feb 3, 2023 | 09:42 AM
I could be just the heater core sweating ever so slightly....
Old Feb 3, 2023 | 01:44 PM
Check out the plumbing for the rear heat, aluminium tubing dosen't hold up as well as it should. It doesn't take much of a leak for the smell to surround the vehicle.
Old Feb 6, 2023 | 12:45 PM
SPAMBURGER's Avatar
On my wife's Jeep Grand Cherokee I noticed that smell and her antifreeze wasn't ever very low. After having the dealer look at it with no success I looked around and saw that the water pump pulley was loose and leaking just a little bit. It only leaked while it was running and burning off so there wasn't ever a noticeable puddle under the car.
trev0006
Jan 19, 2013 09:05 AM
trev0006
Sep 11, 2012 04:35 PM
trev0006
Sep 10, 2012 10:11 AM
dart swinger
Jan 25, 2011 03:12 AM
64fury
Feb 2, 2010 05:42 PM
