good cams
Old Jan 23, 2010 | 09:37 AM
envyedrico's Avatar
Junior Member
good cams
wat cams would b pretty good for a 440 engine i just bought i was lookin at the comp cams but i dnt know the difference in all of them
Old Jan 23, 2010 | 09:40 AM
GEORGE68HEMIRR's Avatar
Member
call comp cams up and explain exactly what you have and what your looking for and they will steer you in the right direction
Old Jan 23, 2010 | 09:47 AM
envyedrico's Avatar
Junior Member
thanks man
Old Jan 23, 2010 | 02:15 PM
it all depends on what you want to do with the car
drag racing?
street/strip?
Old Sep 20, 2011 | 08:50 PM
383man's Avatar
Fury-ous
I used Dwayne Porter at "Porter Racing Heads" and had him custom grind me a solid flat tappet cam. It works great as he is very good. Every car I see with his cams run great. You just give him your eng specs and he will spec out a cam for you. And the price was not bad at all. Ron
Old Oct 5, 2011 | 10:00 AM
burnoutking-1's Avatar
Figure out where you want the power, whether or not you care if it has street manners, weight of vehicle, gearing, etc., what else you want or don't want to do to the engine/ tranny, then you can pick your cam.
I wouldn't use a comp cam either. Just my opinion though.
Old May 29, 2012 | 03:02 PM
Gorts 5th's Avatar
i jst installed a comp cams kit very satisfied https://moparforums.com/forums/image...ies/hello2.gif
Old May 29, 2012 | 03:28 PM
Mr.Duster's Avatar
hughes engines has some pretty nice cams and they sound great. My buddy has a whiplash one in his and it really made it scream.
Old Aug 20, 2013 | 09:04 PM
1968newport's Avatar
Engle cams.
Old Aug 21, 2013 | 08:14 AM
pro-tech's Avatar
Everyone has what they think is the best cam. It is all a matter of opinion. And the list will go on forever. I use Mopar perfomance it was what Carroll Shelby used and if it was good enough for him its surely good enough for me. And my car run fantastic...Bill
Old Aug 21, 2013 | 07:10 PM
PURPLE HORONET's Avatar
First thing you need to figure out is what gears you want to run in the rear, then if you want a different stall converter.
Good_Ol_Boys_Garage
Jul 30, 2011 02:30 PM
will d
May 20, 2010 11:20 AM
deadkelly
Apr 17, 2009 02:36 PM
blue 68 gts
Mar 7, 2009 08:14 AM
fast123adam
Mar 2, 2008 09:48 PM
