4x4 towing
Old Oct 22, 2013 | 04:38 PM
michuy's Avatar
4x4 towing
I just bought a full size 1977 fulltime 4x4 truck that I need to tow. A friend of mine has a tow dolly big enough to handle the weight of the truck. The transfer case has a neutral position, and the trans is automatic. My question is with the front wheels on the dolly, and the transfer case on the neutral position, I assume that the transmission would then also be on the neutral position? The front driveshaft has been removed. Is this a safe way to dolly-tow the truck?
Old Oct 22, 2013 | 06:28 PM
Without consulting "an authority" such as the shop manual, I'd be pulling the rear shaft
Old Oct 23, 2013 | 12:53 AM
Just be safe & pull the drive shaft It takes what ? 15 minutes
Old Oct 23, 2013 | 04:16 AM
I Agree !!!!! Disconnect the D-Shaft...
Old Oct 23, 2013 | 11:01 AM
Yep, I'd take that sucker off, too.
Old Oct 23, 2013 | 01:50 PM
pro-tech's Avatar
Agree to be safe.. Bill
Old Oct 23, 2013 | 03:56 PM
lou3500's Avatar
The neutral position on a 4x4 transfer case is for PTO use, the drive train should not move when the transfer case is in neutral. To run the PTO you place the vehicle transmission in gear [drive] while the transfer case is in neutral and it would have a throttle handle to set the RPMs to run the accessory that is hooked to the PTO [example a hyd. pump] . Unhook the drive shaft to be safe!!!!
Rich Good
May 2, 2013 07:45 PM
samuelcosmo76
Aug 27, 2012 08:20 PM
66Barracuda
Jul 5, 2012 09:54 AM
a.johansson84
Mar 27, 2012 05:07 AM
auerdoan
Nov 20, 2010 04:44 AM
