Originally Posted by TVLynn
(Post 118432)
If an extra qt of oil does not help ? I would try adjusting the pressure relief valve When cold ! it is Ok but when hot . the oil thins and the oil pressure relief releases at 60 psi ????
Billet allu oil pump with external line Adjusting regulator At Cold 85 psi at idle At hot is 40 psi at 1100 rpm And 60 psi at 7400 rpm The strange is that if you gas quickly drop at 50! |
(Post 118426)
Raffa... If you/we think the oil is all getting sucked out of the oil pan.. you can add 1 more quart of oil to see if the problem goes away. If the pressure gets better. Then you know the engine was under oil capacity and that would explain the drop/loss.
Yes I like the External Pump.... Leaves room for the bigger stroke crank and rods... :) I'm Not Much into Multigrade oil..... I like 30W or 40W... Racing.... I use Castrol... But nothing wrong with VALVOLINE VR. I think it holds its viscosity better when we beat the shit out of it.... But thats just my opinion.... :) You got the NOS Fixed? Did you install the CAL-Trac's? Hope you have a great season of racing..And get that 9.90... :) |
Originally Posted by raffaplymouth
(Post 118437)
This is my specs
Raffa, love your car!!
What do you have for the main bearings? stock,3/4 groove,full grove narrow or wide? What clearances are you running? This will effect oil pressure! Did you restrict the oil going to the heads? |
Originally Posted by John Van
(Post 118462)
What do you have for the main bearings? stock,3/4 groove,full grove narrow or wide? What clearances are you running? This will effect oil pressure! Did you restrict the oil going to the heads? Rod clearance is .0013 Main clearance is .0018 Oil thin is castrol 10w60 |
(Post 118447)
Is that a #8AN Line and Fittings Raffa?
(Post 118462)
(Post 118447)
I am Planning on it ... :)
Raffa.... Same place is having a big Auto SwapMeet, if you are here in time. Just wanted to let you know.... :) http://www.pomonaswapmeet.com/event-...w-hours-dates/ Also Other thing to do... http://www.socalcarculture.com/cruise_nights.html |
(Post 118471)
wich 8 AN line ?? Fuel Line ?? is all 10 AN
(Post 118480)
(Post 118481)
The oil Line... Is it #8 ?
(Post 118466)
Look like you understand .. John .. I have v series main bearing and hnd rod bearing ... Receveid 8 years ago from 440 source with kit .. In this year replaced even with the same ... I had put new 2 month ago .. Crank polished is perfect .... This is not good ??
(Post 118485)
Raffa, Your clearances are on the tight side for a race motor, but that is not your problem.
Water temperature 175 f Transmission temp 150 f Oil pressure Idle 45 7000 rpm 65 psi Oil is 10w60 castrol full syntetic 18 may i have the first race.. I have found now the VR1 valvoline 10w60 ... But is not full syntetic ... Im undecided |
That is ok in my book for pressure.... But when you say it goes really low... That I dont like.
Just giving my 2cents worth.... I had a problem with oil pressure when I let off at the top end.... I added a three quart accumulator and that ended all the problems... Sounds like just adding a quart may be the answer here.... Sometimes the oil doesn't get back as quickly as we may think... I know this has already been mentioned but, I'm just agreeing on adding a quart of oil and trying that before much else... This could really be the easiest fix for sure.....
Originally Posted by MReeves
(Post 118501)
Tried with 1 quart more ... Look like better
Cold is the same 85 psi Hot is 50 at idle and 70 at max rpm if you push quickly go at 65 |
Guys .. Wich tipe of pan gasket you use ?? .. I hate silicone ...difficult to clean every time when remove the oil pan for check bearing .. I tried with fel pro blue racing reusable ...but little bit leak ... I hate silicon and glue for gasket !!
It is a Pain.... I use Fel-Pro or Mr. Gasket..... For RTV ( I hate to say it, But I use the GM stuff)
http://dirtyhookerdiesel.com/i-14902...e-sealant.html OR Lawson RTV: http://www.lawsonproducts.com/Lawson...alant/91782.lp |
)) ... I know but difficult to removing !!
Guys ... 2 week ago i have rebuilded the transmission ... Every 20-25 pass .. Clutch destroyed .. This year I have the first race at 18 may .. Tried the transmission on the street look like ok .. Now i have removed the pan for adjust the low band .. closed at 72 lb inches and off 2 turn ... Tried the car and i found a little bit overlap from 2/3 ... Band is too tight ???
(Post 118676)
Guys .. this tread is correct on this section Drag Racing ??
(Post 118688)
Raf, your fine right here. What are you using for clutches? only 20 passes is not good. did you raise the line pressures? |
OK i was a bit harsh, sorry. ill say that what you have done is not easy. i know i could not do it. my dad had many sayings. one was "the faster you go the harder it is to go faster." you ARE going faster that the 68 Hemi cuda when new. 10.80 E.T. i saw ronnie sox in late 68 go that fast off the trailer. but he had Hemi heads and $100,000. of factory research. my idea if you can go 9.90 with out nos that WILL be something.
(Post 118692)
SMR full manual valvebodie reverse pattern Billet steel front drum with 6 disc red alto Stock rear drum with 4 disc red alto Kevlar bands 5 gear planetary Bolt-in sprag Stock oil pump Line pressure is 125 psi no more Converter is ultimate converters 4500 RPM Anti ballonplate Big oil pan with 10 quart of oil dexron 3 No moly additive .. No found in italy |
Originally Posted by moe7404
(Post 118693)
Raf, specs on the tranny sound good! what ratio kick down lever do you have? In your car i would use the 5.0 try using a type "F" transmission fluid instead of the dextron 3.
john |
(Post 118722)
john |
