[QUOTE=Drag Pak;129499]Raffa
Going through some slips and I note a BS/A leaf spring Camaro at 1.337 - 60ft. I would have to research it, but I believe there is a 1964 CC/SA 3800 lb Plymouth here in Div 6 that would be very close to me (60 ft and et.) as he has run with me.[/QUOTE ]PROBABLY I HAVE DECIDED ... 29-12-15 HOOSIER DRAG SLICK 10X15 BILLET WHEELS 6.5 BACKSPACING 1 1/2 LEAF OFFSET IF HAVE NO MORE CLEARANCE TO LEAF I WILL PUT A 1/2 WHEEL SPACER LET ME KNOW IF ALL IS OK ... |
GUYS .. THIS IS THE LAST REAR END UPGRADE !
SPLIT MONOLEAF 1" LOWERED CALVERT 9 WAY SHOCK 4 CLICK FROM SOFT FRONT SHOCK 90-10 CALVERT OFFSET HANGER AND SHACKLE 1 1/2 INCHES WITH EYE LEAF AT UPPER HOLE 1" LOWERED PINION ANGLE IS 3.5 DEGREE WITH CALTRACS ADJUSTED AT 1/2 PRELOAD AT LOWER HOLE CAR IS LOWER 2" ON THE REAR AND 1 1/2 ON THE FRONT TIRES 29-11-15 HOOSIER 26-4.5-15 HOOSIER FRONT RUNNER WHEELS WELD RACING PRO-STAR 10" 6.5 BACKSPACING AND 3" ON FRONT RUNNER http://s17.postimg.org/5gw0m3g9r/IMG_4007.jpg free image upload http://s17.postimg.org/gqoqh1lb3/IMG_4010.jpg hosting immagini http://s17.postimg.org/imbis7a5b/IMG_4014.jpg url immagine |
TIRES CLEARANCE IS 1/2 INCHES FROM LEAF .... AND 3/8 FROM THE FENDER LIP
Man. Only left off the footbrake !!! Wow... That thing looked like it was spinning the tire too the 1000 foot marker.. Really "Walking the Dog" (Moving all over the Track)
I see a teen number or a deep low 9's left on the table buddy.... Way to go Raffa !!!!!!! Sounds Awesome !!!! |
Got in love with the 1970 Cuda when i saw this!
Guys .. you can see the last video !! i need more traction !! best 60 ft 1.44 !! my goal is 1.38
