1970 Cuda 496 10,3 sec
Old Apr 13, 2014 | 01:36 PM
  #31
raffaplymouth's Avatar
Originally Posted by TVLynn
If an extra qt of oil does not help ? I would try adjusting the pressure relief valve When cold ! it is Ok but when hot . the oil thins and the oil pressure relief releases at 60 psi ????
This is my specs
Billet allu oil pump with external line
Adjusting regulator
At Cold 85 psi at idle
At hot is 40 psi at 1100 rpm And 60 psi at 7400 rpm
The strange is that if you gas quickly drop at 50!
Old Apr 13, 2014 | 01:55 PM
  #32
Raffa... If you/we think the oil is all getting sucked out of the oil pan.. you can add 1 more quart of oil to see if the problem goes away. If the pressure gets better. Then you know the engine was under oil capacity and that would explain the drop/loss.
Yes I like the External Pump.... Leaves room for the bigger stroke crank and rods...
I'm Not Much into Multigrade oil.....
I like 30W or 40W... Racing.... I use Castrol... But nothing wrong with VALVOLINE VR.
I think it holds its viscosity better when we beat the **** out of it....
But thats just my opinion....
You got the NOS Fixed?
Did you install the CAL-Trac's?
Hope you have a great season of racing..And get that 9.90...
Bob .. Caltracs installed 2 years ago at bottom hole .. Yes ,,nitrous fixed with switch in 2nd !
Old Apr 13, 2014 | 04:44 PM
  #33
Originally Posted by raffaplymouth
This is my specs
Adjusting regulator
Is that a #8AN Line and Fittings Raffa?
Old Apr 13, 2014 | 08:43 PM
  #34
John Van's Avatar
Raffa, love your car!!
What do you have for the main bearings? stock,3/4 groove,full grove narrow or wide? What clearances are you running? This will effect oil pressure! Did you restrict the oil going to the heads?
Old Apr 13, 2014 | 10:16 PM
  #35
Look like you understand .. John .. I have v series main bearing and hnd rod bearing ... Receveid 8 years ago from 440 source with kit .. In this year replaced even with the same ... I had put new 2 month ago .. Crank polished is perfect .... This is not good ??
Rod clearance is .0013
Main clearance is .0018
Oil thin is castrol 10w60
Old Apr 14, 2014 | 12:06 AM
  #36
wich 8 AN line ?? Fuel Line ?? is all 10 AN
Old Apr 14, 2014 | 12:08 AM
  #37
... yes oil restrictor on heads
Old Apr 14, 2014 | 12:18 AM
  #38
Bob in august will go to los angeles, we are able to meet us at NHRA museum ????
Old Apr 14, 2014 | 07:44 AM
  #39
I am Planning on it ...
Raffa.... Same place is having a big Auto SwapMeet, if you are here in time.
Just wanted to let you know....
http://www.pomonaswapmeet.com/event-...w-hours-dates/
Also Other thing to do...
http://www.socalcarculture.com/cruise_nights.html
Old Apr 14, 2014 | 07:46 AM
  #40
The oil Line... Is it #8 ?
Old Apr 14, 2014 | 08:01 AM
  #41
i know Bob !! will go also in Pomona !!!
Old Apr 14, 2014 | 08:02 AM
  #42
yes .. look like 8 AN from filter to Cooling radiator and 12 an from suck to pump
Old Apr 14, 2014 | 08:54 AM
  #43
John Van's Avatar
Raffa, Your clearances are on the tight side for a race motor, but that is not your problem.
Old Apr 14, 2014 | 11:47 AM
  #44
?? .. Now i tried on street for over 40 minute ..
Water temperature 175 f
Transmission temp 150 f
Oil pressure Idle 45 7000 rpm 65 psi
Oil is 10w60 castrol full syntetic
18 may i have the first race..
I have found now the VR1 valvoline 10w60 ... But is not full syntetic ... Im undecided
Old Apr 14, 2014 | 01:25 PM
  #45
That is ok in my book for pressure.... But when you say it goes really low... That I dont like.
Old Apr 14, 2014 | 03:02 PM
  #46
Just giving my 2cents worth.... I had a problem with oil pressure when I let off at the top end.... I added a three quart accumulator and that ended all the problems... Sounds like just adding a quart may be the answer here.... Sometimes the oil doesn't get back as quickly as we may think... I know this has already been mentioned but, I'm just agreeing on adding a quart of oil and trying that before much else... This could really be the easiest fix for sure.....
Old Apr 14, 2014 | 11:46 PM
  #47
_ OK thanks .. tonight i will try at add 1 quart more !! i will let you know
Old Apr 15, 2014 | 11:52 AM
  #48
Tried with 1 quart more ... Look like better
Cold is the same 85 psi
Hot is 50 at idle and 70 at max rpm if you push quickly go at 65
Old Apr 15, 2014 | 12:08 PM
  #49
Guys .. Wich tipe of pan gasket you use ?? .. I hate silicone ...difficult to clean every time when remove the oil pan for check bearing .. I tried with fel pro blue racing reusable ...but little bit leak ... I hate silicon and glue for gasket !!
Old Apr 15, 2014 | 12:44 PM
  #50
It is a Pain.... I use Fel-Pro or Mr. Gasket..... For RTV ( I hate to say it, But I use the GM stuff)
http://dirtyhookerdiesel.com/i-14902...e-sealant.html
OR
Lawson RTV: http://www.lawsonproducts.com/Lawson...alant/91782.lp
Old Apr 15, 2014 | 09:31 PM
  #51
)) ... I know but difficult to removing !!
Old Apr 20, 2014 | 07:12 AM
  #52
Guys ... 2 week ago i have rebuilded the transmission ... Every 20-25 pass .. Clutch destroyed .. This year I have the first race at 18 may .. Tried the transmission on the street look like ok .. Now i have removed the pan for adjust the low band .. closed at 72 lb inches and off 2 turn ... Tried the car and i found a little bit overlap from 2/3 ... Band is too tight ???
Old Apr 20, 2014 | 10:50 AM
  #53
i Tried the car with 2 1/2 turn and look like retard shift from 2-3 .... i tried with 2 1/4 turn off and look like ok !! my fear is this transmission survive only a race ... around 20 pass ... after this front clutch will be destroyed !
Old Apr 20, 2014 | 10:52 AM
  #54
Guys .. this tread is correct on this section Drag Racing ??
Old Apr 20, 2014 | 12:34 PM
  #55
John Van's Avatar
Raf, your fine right here. What are you using for clutches? only 20 passes is not good. did you raise the line pressures?
Old Apr 20, 2014 | 01:03 PM
  #56
moe7404's Avatar
OK i was a bit harsh, sorry. ill say that what you have done is not easy. i know i could not do it. my dad had many sayings. one was "the faster you go the harder it is to go faster." you ARE going faster that the 68 Hemi cuda when new. 10.80 E.T. i saw ronnie sox in late 68 go that fast off the trailer. but he had Hemi heads and $100,000. of factory research. my idea if you can go 9.90 with out nos that WILL be something.
Old Apr 20, 2014 | 09:31 PM
  #57
Hi john ! this is my transmission :
SMR full manual valvebodie reverse pattern
Billet steel front drum with 6 disc red alto
Stock rear drum with 4 disc red alto
Kevlar bands
5 gear planetary
Bolt-in sprag
Stock oil pump
Line pressure is 125 psi no more
Converter is ultimate converters 4500 RPM
Anti ballonplate
Big oil pan with 10 quart of oil dexron 3
No moly additive .. No found in italy
Old Apr 20, 2014 | 09:35 PM
  #58
You right !! the faster you go the harder it is to go faster !
Old Apr 20, 2014 | 11:36 PM
  #59
John Van's Avatar
Raf, specs on the tranny sound good! what ratio kick down lever do you have? In your car i would use the 5.0 try using a type "F" transmission fluid instead of the dextron 3.
john
Old Apr 20, 2014 | 11:40 PM
  #60
john
4.2 lever ..i dont know f oil ... What is this ??
