1971Demon
Old Aug 3, 2018 | 11:48 AM
Krops's Avatar
1971Demon
I have,a 1971,340 demon having, a,problem gas gauge temp gauge keep on going up and down replaced and checked everything were is,voltage limiter location on rally gauges and would that cause this,problem THANK You
Old Aug 3, 2018 | 03:28 PM
Krops's Avatar
Old Aug 3, 2018 | 03:52 PM
Check all connections at the dash, fire wall and all the grounds also look for exposed wires. I suspect a connection or ground/ grounds.
Old Aug 3, 2018 | 04:06 PM
Krops's Avatar
Krops
Old Aug 3, 2018 | 04:15 PM
Krops's Avatar
Krops
Does not have a separate limiter does,temp gauge have limiter built in temp and fuel gauge goes up and comes down has 5 volts like it should to fuel gauge
Old Aug 3, 2018 | 06:06 PM
Pull the cluster and test it on the bench.... If that turns out good.... You hooked something up and are sharing the same common wire.... You just going to have to chas it, the way I read it...
demott128
Aug 13, 2018 09:04 PM
72cuda
Aug 30, 2013 08:48 AM
mikeynags
Jun 16, 2009 06:31 PM
Dave
May 7, 2009 05:39 PM
65Satellite
Oct 21, 2008 05:26 AM
